Old 02-07-2006, 09:23 PM   #16
pull off the top (black plastic cover)
....(to do that, put it in the open position, then push up on the part where the hinges are)
pull off the carpet on the back of the trunk (you may have to remove carpet from one of the two sides of the trunk to have enough room to move it out. Once carpet is removed, all wires running to trunk will be visible (this is a good time to wire up your sub))
i believe its held in by 3 screws, 1 on the bottom, 2 on top, dont remember exactly.
Im also pretty sure you can remove just the bag and not the opening, but if you remove both it will look cleaner
you're lucky if your sub fits in there, my subs are only 10's and they need a 37x58x26 CM box each
Old 02-08-2006, 12:09 AM   #17
vadim321go
vadim321go's Avatar
my sub is also a 10, and it wont fit in there....but i just wanna try sticking my 10 close to there...see what happens
Proud owner of a 95 325i
Old 02-08-2006, 02:43 AM   #18
Justin e36
Justin e36's Avatar
The entire skibag assembly unclips. You can remove it from the back seat with a flat-head screwdriver. The bag + plastic cover will come out as one piece.
Old 02-08-2006, 03:11 AM   #19
(i'll let you in on my secret to bmw repair, vadim. do what ^^ he says)
Old 02-08-2006, 03:19 AM   #20
paul christians
87325is///MR.EVIL
so you are going to put 10" pass threw right???do a V shape and 2 10"....if do not know what mean I will drawing of ONE on FRIDAY ok.....
87is325///2.7L..EVIL.....
Old 02-08-2006, 03:39 PM   #21
ok paul.
ia ne znaiu pro sho ty hovoresh...
hard time understanding what i said? now you know how i feel. All you techno-sound-people always talk in terms i cant understand...
Old 02-08-2006, 03:52 PM   #22
BlitzSix
6 Speed
Send a message via AIM to BlitzSix Send a message via MSN to BlitzSix
I'm GUESSING he means V shaped like this setup here:
Am I close?
PS, how much would a used 600 watt RMS mono 2 ohm amp be ?
BlitzSix is offline   Reply With Quote
Old 02-08-2006, 05:56 PM   #23
vadim321go
vadim321go's Avatar
Originally Posted by proprone
ok paul.
i dont have ahard time understanding no ya toshe ne znau ochem on
btw for the tip, when i get around to isntalling everything ill put the sub close to the hole.
couple of questions thou and im sure this has been answered b4 but
1. will i have to bypass the oem amp in order for my deck to work? or can i just plug it in and be done with it?
2. same question for the speakers
Old 02-08-2006, 05:56 PM   #24
hmm, that's kinda hot. i dont know i just want someone to tell me what kindof box i should build!
lol vadim what background are you?
Old 02-08-2006, 06:35 PM   #25
paul christians
87325is///MR.EVIL
OK...go SEALED than and they preitty small to start with from .236ft3 to 1.1ft3........
Old 02-08-2006, 06:36 PM   #26
vadim321go
vadim321go's Avatar
im russian, im guessing ur ukranian from the speling.
btw dont build a bandpass, those are the crappiest off all.
if u like sound quality go for sealed (thats what i have)
if u like loud music go for ported. when u can hear a car from a mile away that means they have a ported sub...lots of boom but meh.
basically if ur lisetning to music such as rock/trance u would want to have sealed for sure. anything with precise beats
if ur listening to rap and such u want ported cause of the "phat" base
Old 02-08-2006, 06:40 PM   #27
paul christians
87325is///MR.EVIL
Wow..........
[QUOTE=BlitzSix]I'm GUESSING he means V shaped like this setup here:
Am I close? nice for a bandpass v shape, but not for what IVEN is looking for.
PS, how much would a used 600 watt RMS mono 2 ohm amp be ?[/QUOTE It may very on the brand for this....
Old 02-08-2006, 06:56 PM   #28
Justin e36
Justin e36's Avatar
trance doesn't have precise beats. ... it's 2 or 3 octaves in repetition. Jazz, Swing, Latin, or even R&B have precise bass that carry across the 30 - 200 Hz frequency range.
you won't need to bypass your oem amp, for your deck to work. just plug it in and away you go, same with the speakers.
proprone, that box pictured above is a 4th order plexiglass bandpass enclosure.
Old 02-08-2006, 07:02 PM   #29
paul christians
87325is///MR.EVIL
IVEN here some ideas for you www.subzone.com or www.sudzeromfg.com have fun now.....hehehe.....here is 1 more for you subtomix.com
Old 02-08-2006, 07:40 PM   #30
thanks as always paul
