10-20-2002, 12:35 PM
#1
Couped up
Car: '99 M Coupe & '94 Celica GTS
Radio of choice?
I was wondering if there is a consensus as to which two way radio is the best for group cruising? Sorry if this is in the wrong forum.
regards... I mean over and out,
SpudBoy
'99 M Coupe - Imola/Imola
Signature Pictures by Alezone
original BMW parts
To mod or not to mod? That is the question
10-20-2002, 01:08 PM
#2
Car: Gamitemobile
Well, I used a motorola two way, if you happen to be going down to the states, I suggest you pick one up from there, its like half the price.
Make sure it has subchannels, although we dont use them on our cruises, they're the more advanced radios.
10-20-2002, 01:43 PM
#3
moderationistismingly
Car: 97 328is-02 Impreza
I also have a Motorola, sub channels are a definite must have, but having a rechargable battery is also nice. If you get one that doesn't have the rechargable battery, make sure it at least uses AA batteries, the ones that use AAA batteries drain them really fast, and AAA cost a lot more then the AA's.
Also, some of the motorola's with AA allow you to convert them to recharable battery packs later on, and vise versa (rechargable to AA, for emergencies)
10-20-2002, 01:54 PM
#4
Car: 328is
You'd definitely want subchannels. especially when more people are getting into FRS.
FRS radios generally use 14 designated channels. the higher models offer an additional 38 codes. the 38 interference eliminator codes helps you easily find a clear signal.
FRS radios range is pretty much standard, 3.2km.
i would suggest you stick with the Motorola's because they tend to be of better quality.
the T5420 is good model. the T6310 will give you hands free capability and other options.
batteries will be another option. some use stricktly alkaline's, and the higher models like the T6300 can use both alkalines and Nimh, and also they have cigarette lighter option, but they are more expensive. 3 battery alkaline models will give you like 12 hrs of operation based on 5% send/receive. but nimh only gives you 9hrs (but rechargeable), which is more than enough for cruises.
if size is an issue, than look at the T6200 series. but again, the T5420 is good enough because its the model series that include the additional 38 eliminator codes.
10-20-2002, 04:21 PM
#5
Re: ...
Just to make this clearer, it's 38 eliminator codes per channel. So you have 546 frequencies (14x39, 0-38 subchannels) to use, instead of just the standard 14.
10-20-2002, 04:22 PM
#6
Car: E30 318is Arctic Rot
It's about time we started using these! ..i've been using my motorola a lot for double car trips but I can't seem to get the 3.2 km range everyone says they have.
either way they are inexpensive (2 T5420's with battery packs and a double charger for $100) and much more versitile then CB radio's
10-20-2002, 04:37 PM
#7
Couped up
thanks guys
I just picked up a Motorola 5420. get this... it was black with a red face-plate, will match the interior too
thanks again,
SpudBoy
original BMW parts
