Old 01-29-2006, 02:07 PM   #1
t-im
help my car won't start!
So I try to start my car today, and it just won't start... I can hear it semi-cranking but it just won't start up. Everything lights up, so all power works, and the engine makes kind of a noise, but it just won't go...
any advice?
thanks!
t-im is offline   Reply With Quote
Old 01-29-2006, 02:20 PM   #2
BMW Guy
Mine did that yesterday as well. I have a 93 325is. It would just crank over but would not fire. I have never had a problem before. I finally cranked so long the battery went dead. I gave it a boost and it fired right up. It's working as good as it ever has today. I have no idea what happened but hopefully it does not happen again.
BMW Guy is offline   Reply With Quote
Old 01-29-2006, 02:41 PM   #3
t-im
ya, got ama to come
not the battery, but it evenually cranked...smoke came out etc, let it run a bit and it was smooth as ever.
Gonna start it again a few times later and see what's up
Old 01-29-2006, 05:08 PM   #4
scattymatty
Hmm thats pretty wierd
scattymatty is offline   Reply With Quote
Old 01-29-2006, 05:17 PM   #5
euro*
euro*'s Avatar
sounds like a ur starter went.
euro* is offline   Reply With Quote
Old 01-29-2006, 05:18 PM   #6
325isedan
325isedan's Avatar
fuel pump relay most likely!
250KMH
325isedan is offline   Reply With Quote
Old 01-30-2006, 12:59 AM   #7
325isedan
325isedan's Avatar
keep us posted if u can, sometimes its a burnt out maf metre or even something as simple as not putting the intake boot back on tightly enough.
250KMH
Old 01-30-2006, 01:46 AM   #8
Justin e36
Justin e36's Avatar
any advice?
thanks!
battery could be half-dead, or the battery cable/connections could be corroded and not making full contact. if the starter is dead, the car either won't crank at all or it'll make a bad grinding sound. sounds like lack of electrity since the car simply won't crank fast enough.
Old 01-30-2006, 02:54 AM   #9
Soldo
Soldo's Avatar
I have this problem when my car is not started for more than a day..... but my starter is also toasted, so i'm sure this has something to do with it!
Keven Soldo
