Old 01-29-2006, 12:58 PM   #1
MatyBMW
MatyBMW's Avatar
Send a message via AIM to MatyBMW Send a message via Yahoo to MatyBMW
can't open e36 hood.
Has anyone ever had problems with the hood release latch on an E36?
I can't pop my hood anymore and I've noticed alot of these release levers are pretty sketchy.
Any advice?
--MatyBMW
MatyBMW is offline   Reply With Quote
Old 01-29-2006, 02:39 PM   #2
Justin e36
Justin e36's Avatar
if the release lever is very very loose then the cable broke.. you'll have to go through the drivers side front fender well and manually pull the cable.
Old 01-29-2006, 04:19 PM   #3
325isedan
325isedan's Avatar
my cable broke so i poped out the kidney grills and found the other end of the cable that was still connected and pulled on it and it opened, ur welcome.
250KMH
325isedan is offline   Reply With Quote
Old 01-29-2006, 06:48 PM   #4
JUICY J CAN'T
propr'one's Avatar
dont be a ****ing prick. say thanks for advice that was given to you, and be lucky you found another way of doing it in your case. most of the time, the cable wont snap back far enough that you can open it through the grilles (if your cable is that far forward, it will **** up your fan blades)
hid headlights
Old 01-29-2006, 07:16 PM   #5
325isedan
325isedan's Avatar
it was a joke u **** pm me if u have a bone to pick with me
250KMH
Old 01-29-2006, 08:19 PM   #6
Lug_n_trug
Yeah...gggeeeeezzz propane! While this guy is in his anger management classes, think about your bad behaviour..
Lug_n_trug is offline   Reply With Quote
Old 01-29-2006, 08:42 PM   #7
Justin e36
Justin e36's Avatar
how'd you get the kidney grills off from the outside, and where's your splash tray?
Old 01-29-2006, 11:12 PM   #8
JUICY J CAN'T
propr'one's Avatar
kidney grilles pop right out on the outside, put your hand, fingers together, through the grilles, press down to unlock the clips on top, then work out the bottom. where his splash tray is-- im curious about that aswell.
hid headlights
Old 01-29-2006, 11:30 PM   #9
Justin e36
Justin e36's Avatar
perhaps the 96+ grills?.. the early model grills aren't quite so easy to just pop out.
Old 01-29-2006, 11:31 PM   #10
JUICY J CAN'T
propr'one's Avatar
Never tried pre 96 grilles, could be the case. How are the 96 grilles clipped into place, just plastic notches?
hid headlights
Old 01-29-2006, 11:38 PM   #11
Justin e36
Justin e36's Avatar
no... you can't access it through the grills, the locks are on the outside lip... the chrome surrounds have locks.. 2 top, 2 bottom, and 2 on either side... need a flat head to pry it out, and even then it's not always an easy task.
Old 01-29-2006, 11:47 PM   #12
JUICY J CAN'T
propr'one's Avatar
hmm, sweet, since mine are so easy to take out im soooooooo tempted to steal some (cause mine are broken due to accident)
but if someone stole parts off my bmw i'd be pissed, dont want to do that to anyone who drives a e36
hid headlights
