Old 01-24-2006, 01:25 AM   #1
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
E36 M3 Mass Airflow Meter
is the M3 piece a larger/better performing than the 325 one?
UNDER CONSTRUCTION
Old 01-24-2006, 01:26 AM   #2
the MAF is the same on the 328/m3 from what i know. check realoem
Old 01-24-2006, 09:38 AM   #3
SickFinga
SickFinga's Avatar
US Spec M3 has the same MAF as 32x.
If you want to upgrade, you gotta get Euro Spec or 540/740 MAF.
You'll have to get a software though and I've never seen anyone installing it on 328.
Old 01-24-2006, 10:59 AM   #4
JazzM
325 is the same as 95 M3
328 is the same as 96-99 M3
On an M3 you want to go to a 540 or euro MAF
T.
T.
Old 01-24-2006, 12:40 PM   #5
325iSBimmer
///MMMM VIDA
thanks for the input guys. I saw one on ebay for cheap and think i might just get it as a spare anyways.
UNDER CONSTRUCTION
Old 01-24-2006, 03:07 PM   #6
BennyL
7th Gear Member
BennyL's Avatar
what exactly is a MAF, and what does it do?
Old 01-24-2006, 03:41 PM   #7
325iSBimmer
///MMMM VIDA
Mass Air Flow sensor. it measuers how much air is coming into your motor so that the ECU can determine how much fuel the injectors will pulse out.
UNDER CONSTRUCTION
Old 01-24-2006, 06:04 PM   #8
thinair
moderationistismingly
thinair's Avatar
The MAF on the 325 or 328 isn't a bottleneck, upgrading would be a waste of money.
Old 01-24-2006, 06:52 PM   #9
325iSBimmer
///MMMM VIDA
what about the throttle body. I know dinan makes a throtle body that claims to give about 15hp gain. Does M3 have bigger or do you just get the original bored out to gain the advantages?
UNDER CONSTRUCTION
Old 01-24-2006, 07:03 PM   #10
thinair
thinair's Avatar
The whole intake from the filter to the manifold is identical from the 95 M3 to the 325, and the 328 and 96-99 M3.
A Dinan TB will never get you 15hp. They quote 15 hp with software, and that is being super generous.
Old 01-24-2006, 07:10 PM   #11
325iSBimmer
///MMMM VIDA
oh ok..I'll jsut keep my money for some cams.
UNDER CONSTRUCTION
Old 01-24-2006, 07:31 PM   #12
thinair
thinair's Avatar
There you go
