Old 01-23-2006, 03:09 PM   #1
BennyL
7th Gear Member
BennyL's Avatar
Arrow oil change frequency?
so, every how many KM's should I change my oil?
I've got a 1996 318 convert - it's running non-synthetic.
last oil change was done at Maranello 3,200 KM ago (Nov 19)
for some reason, those morons gave me 10W40 last time. isnt it supposed to be 5W30 for the winter?
so, my questions to you guys are:
what kind of oil should i use?
when should i change?
where do you guys get yours done?
Old 01-23-2006, 03:14 PM   #2
325isRED
325isRED's Avatar
I use BMW 5w30 synthetic (6.50$)
and change my oil religously every 5k
I do it myself, takes maybe half hour
'92 325is 5sp
Old 01-23-2006, 03:25 PM   #3
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
I use 10w30 Mobile 1 synthetic and change it every 8,000km.
UNDER CONSTRUCTION
Old 01-23-2006, 04:35 PM   #4
mpower1226
mpower1226's Avatar
I use dino oil as well but I change everytime I comeback from track.
I usually go track about 2~3 times a month so thats less then 1000 interval.
I change my filter twice a season though. (in the beginning of the season and at the end of the season) The car gets stored during the winter.
My friend owns a shop and it only costs me $15 bucks for drain and refil(including castrol gtx). so I rather use dino and change frequently then have synthetic and wait longer.
Old 01-23-2006, 06:26 PM   #5
Furious
BMW again.
Furious's Avatar
im pretty bad when it comes to oilchanges, i do mine every 5000 on synthetic (lubromolly or mobil1) sometimes earlier, i just feel that oil is so important to your car that its jsut as important to keep the oil top notch, kinda like the theory on spark plugs. i know that the synthetic can go much longer, but i dont care, its a small price to pay for great performance.
Old 01-23-2006, 06:38 PM   #6
BMWF1
Guest
Posts: n/a
I change it when it goes to Yellow.
Old 01-23-2006, 08:56 PM   #7
BennyL
7th Gear Member
BennyL's Avatar
ok, by the sounds of it - everyone uses synthetic. now, what is involved in switching from non-synthetic to synthetic?
Old 01-23-2006, 08:59 PM   #8
BMW_7
Econobimmer Racing
BMW_7's Avatar
I used to change every 3,000, then every 5,000 but now I can't be bothered until it's more tha 5,000......
Vitaliy
Old 01-23-2006, 09:33 PM   #9
325iSBimmer
///MMMM VIDA
you can start by using synthetic next oil change or you could be a bit more thurough and run somesort of engine clean/sludge carbon deposit removing liquid that u pour into the oil and run the engine for 10 min before you drain the oil. (make sure u change the filter too) then use sythetic from then on.
you wont benefit from using synthetic oil if you just use it every once in a while as a "treat" for you car. it doesnt work that way. once you start using synth stick to it. if you feel its not worth it for you then just switch back but dont flip back and forth. The short of it is because synthetic oil is designed to bond(overtime) to the metal and conventional oils generally have more detergents and cleaners in them so you can see where switching back and forth wont be beneficial.
The only concern with synthetic oil in older cars is if a oil seal or gasket is on the border of starting to leak it will almost certainly leak once you switch to synthetic. so just make sure u keep an eye on it.
UNDER CONSTRUCTION
Old 01-26-2006, 10:55 AM   #10
BennyL
7th Gear Member
BennyL's Avatar
ok...
i think i'm gonna stay with regular oil for now.
so what should i use during the winter? 5W30, right? and summer 10W40?
Old 01-26-2006, 05:30 PM   #11
1PhatBeemer
1PhatBeemer's Avatar
I use 5W50 in the winter and i think im going to use 15W40 for summer.
1PhatBeemer is offline   Reply With Quote
Old 01-26-2006, 05:47 PM   #12
BennyL
7th Gear Member
BennyL's Avatar
2 things:
a) are those synthetic or non?
b) can someone explain what the numbers mean in the oil ratings, so i can better understand why people use each type when they do?
Old 01-26-2006, 07:43 PM   #13
Ital_325i
Lost in a world of Chaos
Ital_325i's Avatar
ok...
For any 3 series, except the ///M, I would keep it non-synthetic, unless you track your car often. Synthetic is more expensive, and is thinner, so chances of leaking in higher km motors is greatly increased.
If you can't do you own oil changes, or have a warrenty that doesn't allow your own oil changes, I say take it to Charlie. He's located right off the 401, off Dixie. PM Bimmersport, or find his Advertisement and give him a call. His prices are the best Ive seen yet, hence why I continue to take my car there. Speaking of which, its about that time. Charlie, when can you pencil me in????
I try to get my oil changes done as close to 5000Km as possible. I use non-synthetic. I believe Charlie uses Castrol, but he also has Synthetic, should you choose to switch. Just FYI, once you go Synthetic, you cant change back. Another bonus of getting it done at a BMW specialist/shop is they reset your oil guage, which is always a nice touch.
Ital_325i is offline   Reply With Quote
Old 01-27-2006, 04:26 PM   #14
the bachelor
I just keep adding oil and never need to change it
Faster Than A Speeding Ticket.
the bachelor is offline   Reply With Quote
Old 01-27-2006, 04:57 PM   #15
Antz_Marchin
Antz_Marchin's Avatar
every 5K with BMW synthetic
Antz_Marchin is offline   Reply With Quote
