Old 01-23-2006, 11:59 AM   #1
2007 Rubi
Yummi. For those that are open minded, and can appreciate a good Offroader, here are some pics and the specs of the new Jeep Rubicon.
It is supposed to be highly improved, more versatile, and road friendly(don't know how that is gonna fly with all the hard core Jeepers).
"It will come in three models: X, Sahara, and Rubicon. The longtime 4.0L engine will be gone, although we've been warning you of that for a while. We understood early on that it would be something other than the 3.7L V-6 from the Liberty; it's a 230.5ci 3.8L V-6 that will make 205hp at 5,200 rpm and 240lb-ft of torque at 4,000 rpm, hey, exactly like the Chrysler and Dodge minivans! It will have a compression ratio of 9.6:1. A six-speed transmission will be standard (still the NSG370), while a four-speed auto (42LRE again) will be optional. A diesel will be available for the international market."
The link
http://jpmagazine.com/featuredvehicles/154_0601_07jk/
2007 JEEP® WRANGLER
SPECIFICATIONS
2007 JEEP® WRANGLER
SPECS
Standard Equipment
3.8L V-6 gasoline engine
Four-wheel Disc Anti-lock Braking System (ABS)
Electronic Stability Program (ESP)
Electronic Roll Mitigation
16-inch Steel Wheels
32-inch Outer-Diameter LT255 Tires
Compass and Mini Trip Computer Display, Sahara and Rubicon
6-Speaker Audio System
MP3 and Audio Input Jacks
Single-Hinge Center Pivot Windshield
Lockable Rear Underfloor Storage Bin
Sentry Key
Tire Pressure Monitoring
Rear Head Restraints
Front Passenger Occupant Sensing
Available Equipment
16-, 17- and 18-inch cast aluminum wheels
LT255 tires on Rubicon
32-inch outer diameter tires (Rubicon)
Larger, lockable floor console
Driver’s Seat Height Adjuster
Power Windows and Door Locks
6-Disc CD/DVD audio capability System
Navigation System with Full Map Display
Electronic Sway Bar Disconnect (Std. On Rubicon)
Rock Rails (Std on Rubicon)
Factory-Installed Trailer Tow Package
Modular 3-Piece Modular Hard Top
Sun Rider Top
NVH Reduction Packages
Seat-Mounted Supplemental Side Airbags
DIMENSIONS - EXTERIOR
DIMENSION 2007 WRANGLER
Wheelbase, in. (mm) 95.4 (2423.2)
Track, Front, in. (mm) 61.9 (1572.3)
Track, Rear, in. (mm) 61.9 (1572.3)
Overall Length, in. (mm) 152.8 (3881.1)
Overall Width, in. (mm) w/o mirrors 73.7 (1872.0)
Overall Height, in. (mm) hardtop (with base tires) 70.9 (1800.9) Base
72.3 (1836.4) Rubicon
Overhang, Front, in. (mm) 26.7 (678.2)
Overhang, Rear, in. (mm) 30.6 (777.2)
Turning Circle, ft. (m) 34.9 (10.64) - all
Suspension or Front Axle to Ground, in. (mm) 9.1 (231.1) w/ base tire
10.5 (266.7) Rubicon
Suspension or Rear Axle to Ground, in. (mm) 8.8 (223.5) w/ base tire
10.2 (259.1) Rubicon
Approach Angle, degrees 40.8 w/base tire
44.3 Rubicon
Departure Angle, degrees 37.4 w/base tire
40.4 Rubicon
Breakover Angle, degrees 21.8 w/base tire
Old 01-23-2006, 12:19 PM   #2
johnoz
/OO=[][]=OO\
johnoz's Avatar
I like it. I always liked it this model but found not practical for my needs (urban use) plus it is a harsh ride.
Thisnew one reminds me of a smaller Suzuki Vitara's.
If they offered this in diesel in Canada(they probably will) I would be interested in with one.
The way top comes down is also a great feature.
johnoz is offline   Reply With Quote
Old 01-23-2006, 12:22 PM   #3
jstalin
capitalism=crisis
jstalin's Avatar
Yeah I've always loved jeeps, but they're not very practical in the city.
Rise with your class, not above your class
̿ ̿̿'\̵͇̿̿\o=(•̪●)=o/̵͇̿̿/'̿̿ ̿
jstalin is offline   Reply With Quote
Old 01-23-2006, 12:24 PM   #4
AMI Motorsports
How do you guys figure they are not practical in the city? They are small, decent on gas and the TJ's and up have a decent ride. There is plenty of power and you can park them almost anywhere.
Authorized distributor for FK Automotive, Rieger Tuning (all original parts, NO copies!!), Konigseder Tuning
Coilovers, Body Kits, Taillights & more...
AMI Motorsports is offline   Reply With Quote
Old 01-23-2006, 12:30 PM   #5
jeremy
very nice.. too bad the 4L is gone...
Old 01-23-2006, 12:32 PM   #6
Those 4L are very nice. I love mine, when it is running right that is...
Old 01-23-2006, 12:47 PM   #7
FastM3
is dreaming of ///M's
FastM3's Avatar
No new Jeeps will ever compare to the old boys.
FastM3 is offline   Reply With Quote
Old 01-23-2006, 12:51 PM   #8
SickFinga
SickFinga's Avatar
They havent changed it in 20 years, what the point of this thread?
The one with square headlights was the best looking
Old 01-23-2006, 12:57 PM   #9
I dont see why!!! Look at all the SUV's!!! They are NOT more practical...huge size, bad on gas, hard to park...and the list goes on! The only thing not practical for a Jeep is the cargo space, which is almost non existant...making it the reason why i dont own a YJ/TJ...yet!
Old 01-23-2006, 01:02 PM   #10
"For those that are open minded, and can appreciate a good Offroader"
At least its a vehicle we are discussing...now go moderat some of the non car related b#ll $hit that goes on in Off-topic...
Old 01-23-2006, 01:19 PM   #11
I like the old Rubicon better tho...here it is in its element...offroad!
Old 01-23-2006, 01:41 PM   #12
SickFinga
SickFinga's Avatar
ok, you should seriously relax. I didnt try to say this thread is useless, all I was trying to say that it looks pretty much identical.
Old 01-23-2006, 01:43 PM   #13
And so does 84- and 89 e30's, and 92 and 97 e36, as well as 90, and 96 e34's. Your point? This is A HUGE change for a Jeep. You just don't realize it because you are narrow minded and ignorant.
This thread is in Off topic for a reason, and is for those who are interested.
Old 01-23-2006, 01:48 PM   #14
Yes and No.
Yes, they are more rugged, less modernized, take a bigger beating, and can be fixed in your back yard. This is why I like them. Direct comparison can be a XJ vs ZJ.
No, becuase they lack a lot of the tecnology, and evoution(leafs vs coils), civil manner(take that as you will), and they break more, are more prone to expensive damage, and usually tend to loose their appeal to the younger crowd.
IMO.
Old 01-23-2006, 01:48 PM   #15
SickFinga
SickFinga's Avatar
Exaclty, thats why when 2004 and 2005 BMW 330i for example came out, we dont start thread. Look, there is a 2005 BMW 330i.
