Old 01-22-2006, 06:23 PM   #1
e30_kid89
The Afro-stig
e30_kid89's Avatar
Arrow how much power should i need??
im thinking about how much power i will need from an amp to get a single 10" 800 watt(max) 360 nominal power rating sub booming. not lookin for ne thing weak or too powerful right just something in the middle.
Old 01-22-2006, 06:34 PM   #2
Something around what the sub can handle, or higher.
Don't underpower speakers, slightly overpowering is actually safest.
Old 01-22-2006, 06:35 PM   #3
Kal
maxRealtor
Send a message via MSN to Kal
find an amp that runs at about 300-400rms. You should beable to find a nice kenwood amp for less then $300 at best buy.
Future shop also has some nice deals going on right now with there car audio.
Kal is offline   Reply With Quote
Old 01-22-2006, 06:41 PM   #4
e30_kid89
The Afro-stig
e30_kid89's Avatar
300 - 400 rms? i have EXACT amp imma pick up thanks guys.
btw:mystical i never knew overpowerin was actucally good for the sub....now i wont be scared to push it a lil
Old 01-22-2006, 07:19 PM   #5
Maxim
I think what he means is that having an amp that put out slightly more than RMS of your sub is good (just don't turn it up all the way). Having a amp that can't reach your sub's recommended RMS is bad , because if you turn it up all the way and it starts clipping you will destroy a sub with distortion.
If you overpower a sub you will hear it because it will just start hitting the motor structure, you'll hear it before doing a lot of damage... distortion is a little tougher to hear without practice
Maxim is offline   Reply With Quote
Old 01-22-2006, 07:44 PM   #6
paul christians
87325is///MR.EVIL
to over power is fine,to under power is BIG nono....so you have a sub that can 300rms so you can go with 700rms at 8 o,clock on the gain and flat on bass no +1 or max, you clip it and by.by sub....
87is325///2.7L..EVIL.....
Old 01-22-2006, 10:15 PM   #7
Basically, you want the sub to distort before the amp does. Amp distorition (also known as clipping) is what ultimately kills speakers. So with a powerful amp, when you hear the sub stressing you know to take it down a little. If the amp wasn't powerful enough, the sub would have already blown.
