Old 01-16-2006, 10:35 AM   #1
Hibbing
Sony STR-DA5000ES 170Watts X7 Home Theater Receiver
Mint condition true digital DSD 7.1 channel home theater receiver in mint condition. Comes with everything except box which was misplaced. Will not disappoint. $700.
* 7 Channel Direct Drive Digital Amplifier: 170W x 7 (8 ohms 20Hz - 20kHz, THD .6%)
* Dolby(R) Digital, Dolby(R) Digital EX, dts(R), dts-ES, dts-ES 96/24, dts: Neo6, Dolby(R) Pro Logic(R) II Decoding
* Video Up-Conversion to Component Video
* 2 Component Video Inputs: HD Pass (80 MHz)
* 3 Zone/3 Room Output, RS-232C, 12 V Trig x 3, 1 IR In/2 IR Out
* 2 Way Pre-Programmed/Learning/Macro/LCD Remote Control (2nd Remote Included for Multi-Zone Control)
* Detachable AC
Digital Section
* 7 .1 Channel Decoding
* Dual 32 Bit System (32 Bit Decoding Chip/32 Bit Digital Signal Processing)
* 32-Bit Decoding
* Dolby(R) Digital EX Decoding
* Dolby(R) Digital Decoding
* Dolby(R) Pro Logic(R)II Decoding
* dts-ES Decoding
* dts 96/24 Decoding
* dts(R) Decoding
* dts(R) NEO:6 Decoding
* Digital Cinema Sound System with Cinema Studio EX A/B/C Modes
* Digital Concert Hall Mode
* Sound Field Programs: Cinema - 4; Music - 7; Auto Format Decoding - 7
* Multi Stereo Mode
Amplifier Section
* 7 Channel Power Rating: 170W x 7 (8 ohms 20 Hz - 20 kHz, THD .6%)
* Stereo Power Rating: 170W x 2 (8 ohms 20 Hz-20 kHz, THD .6%)
* 8/4 ohm Rated Amplifier Output
* A/B or A+B Speaker Switching for Front Speakers
* Circuit Devices: Discrete
Inputs and Outputs
* 3 Zone/3 Room (Room 2 A/V Output, Room 3 Audio Output) with Independent Source Source and Volume
* 7.1 Multi-Channel Analog Input/5.1 Channel Analog Input
* 7.1 Channel Pre-Out
* 2 HD Capable Component Video Inputs/1 Output
* Phono Input (MM type)
* 8 Analog Audio Line Inputs/4 Audio Analog Line Outputs
* 5 Optical 2 Coaxial Input (Includes Front A/V)/1 Optical Line Output
* 5 CompositeVideo Inputs (Including FrontA/V)/3CompositeVideoOutputs (Including Monitor Out)
* 5 S-Video Inputs (Including Front A/V)/3 S-Video Output (Including Monitor Out)
* 1 Front Audio Video Input with SVideo, Composite, and Optical Digital
* 1 Composite Monitor Output/1 SVideoMonitor Output/1 Component Video Monitor Output
* RS-232C for Control
3 12V Triggers/1 IR Input/2 IROutput
* Control S Input/Control S Output
* Control A-1 II Input
* FM Antenna Input (75 Ohm Coaxial Type)
* AM Antenna Input (Spring Clip Dual Terminal)
* ΒΌ"" Headphone Jack Output
Construction Features
* Aluminum Panel
* Frame and Beam Construction
* Dual Power Supplies - Un-Regulated, Fully Regulated 2nd Power Supply
* Screw Type Speaker Terminals
Convenience Features
* Sound Field Link
* Full Digital Cinema Sound System
* Equalizer (F/C/Sur/SurB) (B: Bass, M: Mid, T: Treble) B,T/B,M,T/B,T/B,T
* Multi-Channel Decoding Blue LED
* On Screen Display (Through Component/S-Video/Composite Monitor Output)
* Component Video Up-Conversion from Composite or S-Video
* 30 Total Station Presets
* 2 Switched AC Outlets, 120 W/1A Max
Hibbing is offline   Reply With Quote
Old 01-16-2006, 02:31 PM   #2
touchofclass
1999 BMW 740i BMW 2000IT
How much?
touchofclass is offline   Reply With Quote
Old 01-16-2006, 02:33 PM   #3
Hibbing
Oops $700.
Old 01-16-2006, 05:47 PM   #4
Hibbing
Retail was $2800.
Old 01-16-2006, 07:21 PM   #5
touchofclass
Bud the new price is $1059.00 US$ but a great deal at $700 bump
Old 01-18-2006, 03:49 PM   #6
GR8 Ride
GR8 Ride's Avatar
Send a message via ICQ to GR8 Ride
Actually, you can get it for $598 from ExpressAudioVideo.com (run a price search at pricerunner.com), but it's not too far off.
I could be interested at $500 CDN, but not anymore than that.
Pat
I'm not really an asshole, I just play one on the Internet
GR8 Ride is offline   Reply With Quote
Old 01-18-2006, 04:43 PM   #7
calegrant
$2800? I don't know where you get your figures but our shop can order those units for less than half that price.
Old 01-21-2006, 07:08 AM   #8
Hibbing
The MSRP and selling price at Sonystyle was $2799, that's where I got the price. It typically streeted at $2300. Is $700 a good price? Damn right it's a good price.
Old 01-21-2006, 10:05 AM   #9
daytona
Hibbing always have good prices so stop dumping on his sales..
daytona is offline   Reply With Quote
Old 01-21-2006, 10:08 AM   #10
Hibbing
Yeah leave him alone.
Old 01-21-2006, 02:59 PM   #11
Sickbimmer
750HP turbo E46 M3
Sickbimmer's Avatar
Bump for a great seller
Sickbimmer is offline   Reply With Quote
Old 02-03-2006, 10:49 AM   #12
bimmerod
Sold?
PM me.
bimmerod is offline   Reply With Quote
Old 08-19-2009, 01:40 PM   #13
brian076
Hi,
still for sale !
brian076 is offline   Reply With Quote
Old 08-19-2009, 03:10 PM   #14
Quack
Wheelman
Quack's Avatar
Originally Posted by brian076 View Post
Hi,
still for sale !
you should check the date, this thread was started over 3yrs ago
