Old 01-15-2006, 01:18 PM   #16
TEUTONICFOOL
only if the bloody lock heater relay is still working.
TEUTONICFOOL is offline   Reply With Quote
Old 01-15-2006, 02:08 PM   #17
ZiMMie
Originally Posted by e30_kid89
where?
instalation its somewhere on R3v.4 wire installtion
#E36-S54 #CSLWannabe
Old 01-15-2006, 02:09 PM   #18
ZiMMie
where?
where else but ebay
http://cgi.ebay.com/ebaymotors/Omega...spagenameZWDVW
http://www.r3vlimited.com/board/show...ght=power+lock
Old 01-15-2006, 02:11 PM   #19
BmW1718
Send a message via MSN to BmW1718
they have it i don't no how to make it work i had to replace mind but don't no how to make it work what's wrong it wd 40????
BmW1718 is offline   Reply With Quote
Old 01-15-2006, 02:42 PM   #20
blacknblue-e30
Just black, No blue
blacknblue-e30's Avatar
Send a message via MSN to blacknblue-e30
White lithium grease in a spray bottle from crap tire.
You will never have a problem again with a proper application.
blacknblue-e30 is offline   Reply With Quote
Old 01-15-2006, 02:51 PM   #21
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
i use lock de-icer in arosol, keep it in my jacket pocket. kinda ghetto, but give it a squirt BEFORE you leave the car, and you'll be fine.
Old 01-15-2006, 03:13 PM   #22
2002guy
Send a message via MSN to 2002guy
you can also take the door panels off and give them a ince oil treatment on the locks
2002guy is offline   Reply With Quote
Old 01-15-2006, 05:21 PM   #23
e30_kid89
The Afro-stig
e30_kid89's Avatar
Originally Posted by arsevader
Most if not all Canadian spec E30s have this feature. This is the reason we can't have timer delay interior lights.
Cdn E30s have heated locks, heated side mirrors and I think all have heated washer nossles.
James
so how do i activate it? i kno mine for sure is canadian spec
Old 01-15-2006, 09:12 PM   #24
good ol' locking de-icer from Crappy Tire... on sale for $.49.... did the trick for me after I 'smartly' washed the ride... good stuff, just poke it into the lock, spray, and voila, its good. Cheers
Old 01-15-2006, 09:23 PM   #25
marco328is
marco328is's Avatar
there is a module in all e30's and e36's that when you put your key in the cylinder it heats up and allows you to unlock and lock your doors freely.
If your doors are freezing up your module is all $$$$ed up. it's pretty pricey to fix but worth it as you can cause more damage to your cylinders which will cost more money to fix. about $550.00CND to be exact. each unit
marco328is is offline   Reply With Quote
Old 01-15-2006, 09:55 PM   #26
e30_kid89
The Afro-stig
e30_kid89's Avatar
so u just stick it in & wait? how long should it take till its melted? imma go try this like at 2 am
Old 01-15-2006, 10:38 PM   #27
I don't think you use the key, I think you pull up on the door handle while locked. Anyone else?
Old 01-16-2006, 09:28 AM   #28
BmW1718
550$$$$$ wow i went to the jumk yard and got myself it for 5$ and did it myself
Old 01-17-2006, 12:19 AM   #29
Mavrick
I'm interested in this heated locks feature.. sounds sweet - but i doubt mine works. That'd be awefully nice.
How hard of a job is it to remove the door panels? That makes the most sense to me.. attack the sumbitch with lithium grease.
Mavrick is offline   Reply With Quote
Old 01-17-2006, 12:45 AM   #30
Justin e36
Justin e36's Avatar
Yes, the heated lock are activated after 5 seconds of holding the driver's door handle up. It will automatically turn off after 30 seconds, and you may have to repeat.
White grease is too thick to reach the components of your locking mechanism that will freeze up, what you need is F temperature oil sprayed in a few times, then work the locking mechanism to lube it up. The latching mechanism, however, you should use white grease for.
The question though, is, why are your locks always freezing? Was your door panel removed at one time, and someone removed the vapor barrier, didn't reinstall it properly, or put a hole in it?
There is a little metal cover that goes over your locks, it is spring loaded. Is it not covering fully on your driver's door, which allows water and moisture to get in?
Have you tried blowing out / drying all the water in there with a can of compressed air?
Instead of focusing on how to band-aid the problem and live with it, you should focus on why the problem exists, and how to solve it.
