Old 01-14-2006, 09:10 PM   #1
Mavrick
Removing Rear Hub - Please help asap
I would like to get this back together tonight so i can drive to work tomorrow.
I am wondering if i can remove the rear hub without touching the CV jont/half shaft?
Thanks,
Mavrick is offline   Reply With Quote
Old 01-14-2006, 09:18 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
u cant. but if u already got it off without touchin the drive axle the put a pice of wood on the drive axle, push in the spline so it starts to fit into the hub and hammer away........well thats how i did it, if u wanna do it the safe and proper way u must get it press-fit.
Old 01-14-2006, 09:20 PM   #3
Mavrick
Thanks for the reply!
Maybe your not understanding.. i just have the brakes off as it is now and I want to remove just the hub.
Can i remove the hub, and then re-install?
Or do i have to remove the CV shaft from the hub?
Old 01-14-2006, 09:24 PM   #4
e30_kid89
The Afro-stig
e30_kid89's Avatar
oooo i see. yes u have to remove the driveaxle. its not too hard, just remove the 6 bolts that hold it to the flange and use a puller to push it out of the hub.
Old 01-14-2006, 09:27 PM   #5
Mavrick
I don't have a puller. This is a bummer.
Old 01-14-2006, 09:32 PM   #6
e30_kid89
The Afro-stig
e30_kid89's Avatar
why are u removing the hub?
Old 01-14-2006, 09:35 PM   #7
Mavrick
If i were to remove the half shaft, would the hub then just pull out?
I have to remove the shock to get in there i bet?
Old 01-14-2006, 09:37 PM   #8
Mavrick
I am removing the hub to get at the e-brake cable bracket, to remove the e-brake system as it was causing squeeks against the rotor. One of the bolts is rounded off and a wrench won't do the trick.. i need to get a socket on it. I either need a universal 14mm, or remove the hub and it'd be cake. I figured i may be able to sneak a 1/4" 14mm with wratchet in there behind the hub, but i don't have that socket - none of my buddies do either.
Old 01-14-2006, 09:42 PM   #9
e30_kid89
The Afro-stig
e30_kid89's Avatar
yes u will have to remove the shock. but for what u are doing, u should try to get that rachet cuz it will save u alot of time/money for new parts because after u get the drive axle off, if u remove the hub it will have to be banged out from behind or pulled out with a hub puller. plus removing the hub will damage the wheel bearing which will need replacing on when u r putting everything back together.
Old 01-14-2006, 09:44 PM   #10
Mavrick
Ahh ok. Thanks for the advice. I'm gonna head out and throw everything back together for tonight.
Jeff.
Old 01-14-2006, 09:50 PM   #11
Jordan
You realise if you remove the hub from the trailing arm you will destory the wheel bearing in the process right, and will need a new one...
Leave the ebrake shit alone, or fix it. Don't just remove it.
Old 01-14-2006, 10:09 PM   #12
Mavrick
Thanks,
I didn't realize i would ruin the bearing, so i'm glad you guys clued me in on that one.
The e-brakes will be replaced, but our BMW mech. is over an hour away, so i was looking to delete them temporarily.
