Ok got home today and took my wheels off, checked driver side, no play nothing, solid as a mother f'r, put the wheel back on. Went to the driver side, visual inspection ok, grabed this grabed that shook, ok, Grabbed the tierod, BAM WIGGLIN LIKE A MOTHER ****ER. Still firmly attached but i could wiggle it back and forth with out using muscle
SO i found the problem (with all your help, specialy the one who mentioned the tie rod).
Now the passneger side tie rod needs replacing. Two questions, one everything else is ok firm clean no problems should i have to change anything else or just remove the old and put in a new?
and second, the site im looking at
http://www.bmaparts.com/epcvsoapimc....entid=bmaparts
Has the tie rods, which is left which is right which one is passnger sid. I can never remember if it goes by you facing the car or you sitting in the car. im guessing looking head on.
SO i plan on basicly just removing the tie rod myself. is it just bolted in, just remove the bolt(s) and it will come right off? Then afterwards ill have the car aligned. save my self a few bucks.
thanks again everyone for your input
