Old 01-11-2006, 05:44 PM   #1
BMW325BMW
Commando
BMW325BMW's Avatar
stereo install/ antenna problems
up until now i have just been to lazy to actually check why my antenna does not work anymore. it was working fine up until i installed my amp and sub. i thought maybe there was a loose connection somewhere but i pulled the deck today and checked the antenna in the trunk. everything is connected. has anyone else run into this problem? any suggestions?
thanks for any input
BMW325BMW is offline   Reply With Quote
Old 01-11-2006, 06:32 PM   #2
Jordan
There is a fairly large solid white wire in the dash around the headunit that needs +12v for the antenna to go up. At the antenna there are 3 wires.
Red (constant key on +12v)
Black (ground)
White (HU tuner +12v)
Turn key on to last position before start. Apply +12v to the white wire at the antenna. Antenna should go up. If it does not check for +12v at the red wire at the antenna. If no voltage there the problem is the red wire.
Red wire runs to the front of the car and plugs into the main molex connector on the firewall behind the ABS computer. From there it goes straight to the fusebox. Fuse 12 I think, but don't hold me to that.
Old 01-11-2006, 06:36 PM   #3
King Luis
The King.
King Luis's Avatar
i'm assuming jordan doesn't have antenna/radio but if you do how did you mount your new one?
or
is there anywhere i can put an antenna that wouldn't be visible outside the car?
i know newer cars have them in the rear window. btw, i don't have a power one and my reception isn't too good with any station. sometimes its good, other times it sucks.
Mods: TBD.
Sold:2004 Silver Gray M3
Gone:1990 Brilliantrot 325is
Old 01-11-2006, 06:56 PM   #4
Jordan
I don't a antenna. I welded over the whole and shaved it.
I don't even have a radio/stereo/speakers anymore. Sold it all.
No tunes.
Most new BMW's have a second matrix in the rear window for the antenna. This isn't an option on a e30. You can't just use the defroster matrix. Won't work.
Use a e30 M3 style antenna, or the ones that stick on the rear glass.
Old 01-11-2006, 07:19 PM   #5
e30_kid89
The Afro-stig
e30_kid89's Avatar
so jordan u have nothing in ur car at all? do u plan to keep it that way??
Old 01-11-2006, 07:30 PM   #6
Jordan
Yes, yes.
Dude you can't hear the system unless it was freaking cranked beyond a comfortable level anyways.
I have headers, straight mid section, and a straight through muffler that is basicly for looks. I also do not have a single ounce of sound deadening. Shit is loud.
Old 01-11-2006, 07:31 PM   #7
BMW325BMW
Commando
BMW325BMW's Avatar
all the wires that are left loose are the ones that used to run to the factory amp... i found 2 white wires, both with female plugs on them, but no red wire
if it helps it's an 87 325i
Old 01-11-2006, 07:58 PM   #8
e30_kid89
The Afro-stig
e30_kid89's Avatar
Originally Posted by Jordan
Yes, yes.
wut did u fill the big hole in the dash with?
Old 01-11-2006, 10:07 PM   #9
paul christians
87325is///MR.EVIL
ONE of the white wires will another colour on it.
87is325///2.7L..EVIL.....
Old 01-12-2006, 11:11 AM   #10
AMI Motorsports
http://www.stylinconcepts.com/parts....categoryid=286
Here is a kit I have used before.
Authorized distributor for FK Automotive, Rieger Tuning (all original parts, NO copies!!), Konigseder Tuning
Coilovers, Body Kits, Taillights & more...
AMI Motorsports is offline   Reply With Quote
Old 01-12-2006, 08:31 PM   #11
BMW325BMW
Commando
BMW325BMW's Avatar
Originally Posted by AMI Motorsports
and it plugs in to the regular antenna jack? and good signal?
and both white wires are useless... as far as i can tell
Old 01-13-2006, 01:13 PM   #12
AMI Motorsports
Correct worked on my Jeep fine.
Old 01-13-2006, 02:33 PM   #13
1BADRIDE
TECHGURU
Send a message via MSN to 1BADRIDE
BMW325BMW...I met you once before @ Sunoco McCowan/14th. If you want, pass by and I'll look at the wiring. I had no problem fixing my antenna, and I have a complete testing and working unit handy as well.
2010 BMW 335D - Many mods to come!
1BADRIDE is offline   Reply With Quote
Old 01-13-2006, 07:36 PM   #14
BMW325BMW
Commando
BMW325BMW's Avatar
sounds good... pm me and leave me an addy or number i can reach u at... any help would be great
