Old 01-09-2006, 08:40 PM   #1
sicilianace
E-thirtysexer
sicilianace's Avatar
Send a message via ICQ to sicilianace
New E30 owner-need help???
1. I notice the check light comes on and off quite often???
2.Brake lining light is always lite up,same for the inspection but the green light are lite up.
Thanks,
e36 325is
e30 m3
sicilianace is offline   Reply With Quote
Old 01-09-2006, 08:50 PM   #2
paul christians
87325is///MR.EVIL
2 lining light comes on because they need doing(the brake), the green ligths are telling you is a oil change, the check light come beccause your o2 failing...OH yes I found the HAND BOOK.....
87is325///2.7L..EVIL.....
Old 01-09-2006, 09:21 PM   #3
sicilianace
E-thirtysexer
E30 owner -needing help
Thanks, Paul for the info, I've just purchased a clean owners manual from a member, I like to have my own....I appreciate the thought.
P>S> I've started to get the hang of that reverse gear....im goin to need to fix all that play in the gear shift............
e36 325is
e30 m3
Old 01-09-2006, 10:02 PM   #4
paul christians
87325is///MR.EVIL
COOL dude, and hope it goes ok, and if you my help just ask away...
Old 01-09-2006, 10:34 PM   #5
TEUTONICFOOL
looks like ur circuit board is acting up.
TEUTONICFOOL is offline   Reply With Quote
Old 01-10-2006, 09:21 AM   #6
BmW1718
Send a message via MSN to BmW1718
my brake lining is on too and i think it's because on the rear disc on the back there wires and there not connected to anything could that be why
BmW1718 is offline   Reply With Quote
Old 01-10-2006, 10:07 AM   #7
Chris de la Cruz
sex, drifting & punk rock
yeah just change your sensors
www.CSCS.ca
Old 01-10-2006, 10:37 AM   #8
E30 Girl
E30 Girl's Avatar
Send a message via MSN to E30 Girl
When you do a brake job you have to replace the sensor as well or the little light will not go off. That or it isn't connected anymore.
E30 Girl is offline   Reply With Quote
Old 01-10-2006, 11:21 AM   #9
i got new brakes for my beater when i started driving it last month, new everything, even the sensors and the light is still on
Old 01-10-2006, 12:56 PM   #10
Chris de la Cruz
on mine... the wires are severed so even when i replace the sensor the light is still on. haven't gotten around to fixing that yet
www.CSCS.ca
Old 01-10-2006, 03:09 PM   #11
paul christians
87325is///MR.EVIL
Check the connection, it may need to be CLEANED.....Yes if the light is on...
Old 01-10-2006, 03:51 PM   #12
BmW1718
there is no connection on mind werid
Old 01-10-2006, 04:28 PM   #13
paul christians
87325is///MR.EVIL
yes there is some type of connection, if you the HAYNES,CHILON'S or the other one look up the brakes and it tell you and show what I mean..CHEERS..
Old 01-10-2006, 08:36 PM   #14
sicilianace
E-thirtysexer
New E30 owner
Hey, guys and gal noticed today the check light flashes only as i start the car, then it goes off. The brake lining light stays on(perhaps it needs new pads and sensor), same for the inspection light(never reset).
Thanks for your suggestions,
e36 325is
e30 m3
Old 01-10-2006, 08:43 PM   #15
johnoz
/OO=[][]=OO\
johnoz's Avatar
I have a free Bentley manual for e30 to give away since I don't think I will ever own one.4 is more than enough. Pick up DT Toronto.
johnoz is offline   Reply With Quote
