Old 01-08-2006, 10:17 PM   #1
bmnorm
bmnorm's Avatar
understeer short shift kit
Does anyone have the short shift kit from understeer.com?
The one for $85. I just ordered the fan delete kit with aluminum housing and metal water pump. I was thinking of getting the short shift kit, but it looks cheap.
if anyone has it installed, would you recommend it?
bmnorm is offline   Reply With Quote
Old 01-08-2006, 10:27 PM   #2
thinair
moderationistismingly
thinair's Avatar
Send a message via ICQ to thinair Send a message via MSN to thinair
It's nothing special, just a bent OEM ZM3 shifter. I have the same setup, it can be bought at any dealership.
It's not bad, just don't expect a B&M or UUC StgIII feel. Sure beats stock anyway.
Old 01-08-2006, 10:54 PM   #3
bmnorm
bmnorm's Avatar
cool, thanks for the quick reply.
Is it cheaper to get the shifter from the dealership or from understeer?
I just pm'd you also.
thanks again
Old 01-08-2006, 11:03 PM   #4
thinair
thinair's Avatar
I believe the shifter lever itself is $90ish, but then you have to bent the lever or else it won't sit in centered. Plus the pivot cup, clips and washers add about $15 on top of that. The understeer lever comes pre-bent.
