Old 01-06-2006, 01:27 AM   #1
Jim .E.
E90 n00b
Jim .E.'s Avatar
Comp Advice: Building Dual Opteron 240
planning on building a Dual Opteron 240 system with about 2GB of ram...was wondering about the following questions:
- is it worth it?
- what motherboard?
- are they relatively stable to overclock? if so water cooling or 2 Scythe ninjas would be suffice?
i wont be building the beast until about summer but i want a heads up on if itll be beneficial or not (looking to create a server out of my old pc and make this into a gaming rig and just make it powerful so i dont have issues with render times when i start modelling heavily with the cg apps i have)
Old 01-06-2006, 11:11 AM   #2
Harry
Opterons are generally intended for stable server use. You will not find too many system boards that lend themsleves well to overclocking. It is possible though.
As for which board to use, it is best to define what you intend to do with said system. If you want cheap, you can get an MSI or tyan board. No PCI-X, but AGP, RAID, SATA, up to 4GB REG ECC.
With all of the opteron boards you will need Registered ECC.
Harry is offline   Reply With Quote
Old 01-06-2006, 12:16 PM   #3
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
Fuu this just came up on another board.
I think over clocking is possible, but "stock" the latency will be so low that
you won't really need to.
especially if sata'd with paird pc3200+ (or whatever) ram
I can run CoD2 & BF2/ Bf2 special forces on my 2800+ (2ghz) Semperon that i built.
so 2cpu's is just overkill
Old 01-06-2006, 12:41 PM   #4
rhythm
Dual Opteron 240's wouldn't qualify as a "best" anymore, they are 1.4ghz. You're best bet is to get a DualCore AMD64 and some ram. It would be a lot cheaper and faster.
rhythm is offline   Reply With Quote
Old 01-06-2006, 12:59 PM   #5
Proliphic
Trying to stay on 4wheels
Proliphic's Avatar
Send a message via MSN to Proliphic
If I were you id look into getting the Athlon 64 4000+ @ 2400 MHz,
price is about the same as the 2 Opertons
wider selection of motherboards, less heat, great gaming powerouse cpu
heres a link to show performance diff over the P4 550 @ 3400 MHz
http://www.amd.com/us-en/Processors/...5E9585,00.html
Granite Silver '92 325i
Mark D (93) Chip
Motronix CAI
(Magic Fairy Dust )
Strut Brace
APEX Sport Springs
18" M3 CSL look-a-like's
Clear Corners All Around
6000K HID's
Thinline Angel Eyes
2.
Black/Silver 2000 Suzuki Hayabusa GSX1300R
8000K HID's
Clear Signals
(More to come)
Proliphic is offline   Reply With Quote
Old 01-06-2006, 01:13 PM   #6
Harry
Is that a crack piep I see? Must be.
The 240's go for about $60 each on 2cpu. 4000+ = $410. Cheaper for the 240? No. There is also no chance of the 40's being hotter than a 4000+.
Old 01-06-2006, 01:13 PM   #7
Proliphic
Proliphic's Avatar
Cheaper ??? the DualCore are a lil bit of a jump in price..
64 4000+ = around $400
Dual Opertons 240 = around $400
64 DualCore 4800 = around $800
and for not much of a diff as far as bang for your buck goes.
Image Below is from http://techreport.com
Mark D (93) Chip
Motronix CAI
(Magic Fairy Dust )
Strut Brace
APEX Sport Springs
6000K HID's
Thinline Angel Eyes
2.
8000K HID's
Clear Signals
(More to come)
Old 01-06-2006, 01:20 PM   #8
Proliphic
Proliphic's Avatar
well off Pricewatch.com Operton 240s going for $158 USD per cpu
not sure where you get your CPUs but id like to get the hook up lol..
Mark D (93) Chip
Motronix CAI
(Magic Fairy Dust )
Strut Brace
APEX Sport Springs
6000K HID's
Thinline Angel Eyes
2.
8000K HID's
Clear Signals
(More to come)
Old 01-06-2006, 01:22 PM   #9
rhythm
They don't sell opteron 240's anymore, so they can't be the same price as the 4000+. You can get them used for about $50-$60.
Old 01-06-2006, 01:24 PM   #10
rhythm
You also might want to take into consideration the cost of a good stable dual motherboard, and don't forget that ECC ram will run you into the ground.
