Old 01-04-2006, 08:54 PM   #1
4-banger
where to get a beer funnel?
4-banger is offline   Reply With Quote
Old 01-04-2006, 08:57 PM   #2
blacknblue-e30
Just black, No blue
blacknblue-e30's Avatar
Send a message via MSN to blacknblue-e30
make one, large sized cone funnel, 10 ft of 1.5 clear hose, 1 turn valve, a clamp for hose and funnel and your done, get shitfaced.
blacknblue-e30 is offline   Reply With Quote
Old 01-04-2006, 09:05 PM   #3
sirex
King Sirex
holy crap its called making one!!!!1
I made the best beer hat in the world with my friend..
Materials we used:
Consturction hat ( it was from U of T)
Drilled a hole on the top about 1.5 inchses..
Got a 3 foot plastic see through pipe - one that is okay for human consumption.
Got the nut and the bolt.. Had to find a hollowed out Nut though, we found them at the hardware store.
Added the tube to the bolt, connected with some of those metal tie things.
Used some silicon, and some rubber washers to help create a good seal
and there we had it.. awesomely good beer funnel.. ill try to get some pics of it...
Key things to remeber in consturction of beer funnel:
You dont need a very thuick tube.. 1.5 inches is more thene enough ifits going to be a few feet long.
when you are done with the funnel make sure you run water through it, do not let beer sit in it!
Old 01-04-2006, 09:27 PM   #4
Kal
maxRealtor
Send a message via MSN to Kal
rookie.
You need a good size funnel and a long tube (minimum 6 feet). Stick the funnel into the tube.
Kal is offline   Reply With Quote
Old 01-04-2006, 09:37 PM   #5
sirex
King Sirex
6 feet is stupid... man my beer funnel is so good, it easily holds 2 tall cans, and there is no way anyone in there right mind will funnel more then that.
Old 01-04-2006, 09:44 PM   #6
Mitch555
Retired MaXmember!
Mitch555's Avatar
Since you seem like you'd rather buy one... I saw them being sold at Spencers in Square One. You can stop the flow of beer with these if it becomes too much or if you are ready to puke or can't take anymore so you don't waste beer.
MY ENGINE SWAP: HERE!
Life Is A Tough Teacher, It Gives You The Test Then The Lesson.
Originally Posted by Mystikal
just do it once, do it right.
Mitch555 is offline   Reply With Quote
Old 01-04-2006, 09:49 PM   #7
2 funnels, 2 splitters, 4 valves, each independantly controlled, same with the funnels.
you guys are all rookies
Old 01-04-2006, 10:39 PM   #8
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
When you use a funnel that uses a bike pump to get pressure to shoot it down your throat you know whats up.
Stanceiseverything.com
Old 01-04-2006, 10:41 PM   #9
BMWags
BMWags's Avatar
for one of our funnels we cut off the top of a watercooler jug, 4 different hoses with ball valves too.... also have a simple no frills funnel and tube that holds about 10 litres.
Old 01-04-2006, 11:05 PM   #10
thinair
moderationistismingly
thinair's Avatar
Who needs a funnel
- Get an air compressor
- fill the tank with a couple litres of beer
- charge the tank with about 100psi
- position your mouth in front of the purge valve
- open mouth
- pull purge valve pin
- enjoy
Old 01-04-2006, 11:07 PM   #11
BMWags
BMWags's Avatar
Originally Posted by thinair
Who needs a funnel
- open mouth
- enjoy
LOL, direct beer injection
Old 01-04-2006, 11:15 PM   #12
like alcohol injection for our turbos
Old 01-05-2006, 10:10 AM   #13
Kal
maxRealtor
in any case, beer funnels suck... they don't get you as drunk
Old 01-05-2006, 11:59 AM   #14
BMWFORLIFE
Technoviolet Shifting
Hommmmmeeeeeeee Deeeeeeepppppppoottttttttttttttt
BMWFORLIFE is offline   Reply With Quote
