Old 01-04-2006, 10:29 AM   #1
uber e36
uber e36's Avatar
'92 325i (M50) benefits?
Hey guys,
What are the benefits of the '92 M50 vs. later M50s? And was there a hp or torque difference?
Thanks,
-Geoff
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
Old 01-04-2006, 10:58 AM   #2
Justin e36
Justin e36's Avatar
Originally Posted by geoff@bmw
Hey guys,
Thanks,
-Geoff
I believe you mean M50 non-vanos compared with M52 vanos engines.
It depends really because the M50 came in 320/325 (520/525) and the M52 came in 320/323/325/328 (520/525/528) configurations. I'm not sure which ones you want to compare. There may be other configurations too, but I think that was all?
This should help though... M52 Specs vs M50 Specs.
J
Old 01-04-2006, 02:08 PM   #3
uber e36
uber e36's Avatar
Justin,
Isn't the M50 a 2.5 and the M52 a 2.8?
Also, I'm pretty sure there's something about a '92 M50 that makes it different from the +92 M50s? (thicker walls, rods, double springs, etc)
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
Old 01-04-2006, 02:09 PM   #4
Soldo
Soldo's Avatar
I think he is refering to just the 2 M50 engine options!
I believe the power was the same, but the VANOS M50 came with more torque..... the only benefit that i've know/heard of, is that the NON VANOS M50 motors came with dual valve springs, which help make the engine more rev happier (one the limiter is removed!)
Keven Soldo
Old 01-04-2006, 05:29 PM   #5
there are different kinds of m50's and m52's
for instance, i have an m50b28 (cause i have teh l33t0r 2.8 litre( i want a s52))
anyways, you can also have m52b25, m52b20, etc
last 2 digits is usually displacement
Old 01-04-2006, 06:22 PM   #6
PedroBMW
Hooked on Boost
PedroBMW's Avatar
I can testify that the 92 325is 2.5L(non-vanos) is noticiably more rev-happy than the m50 2.5L WITH vanos. The vanos engine is more driveable though than the non-vanos. I had a 92 325is and it was lots of fun when the revs were up, my cousin had a 94 with (vanos), so I had quite a bit of experience with it too. I think the max horsepower and torque are the same for both, just the delivery is different.
http://www.foldingtrailers.ca
Old 01-04-2006, 10:25 PM   #7
thinair
moderationistismingly
thinair's Avatar
Ok, M50B25, thicker valve stems, hotter cams, double valve springs, no VANOS. They do have limiters, I don't know where that came from.
M50B25tu, VANOS engine
M50B20, 320 engine
M50B30, 95 NA M3 engine
M52B28, 328 engine with VANOS, forged crank
M52B25, 323 engine, detuned 2.5L
M50B28, doesn't exist.
M52B32, 96-99 NA M3 engine
Old 01-04-2006, 11:56 PM   #8
uber e36
uber e36's Avatar
M50B20, 320 engine
S50B30, 95 NA M3 engine
S52B32, 96-99 NA M3 engine
Thinair,
Am I wrong in making the above changes?
Also, how come 325 isn't listed there?
-Geoff
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
Old 01-05-2006, 12:11 AM   #9
thinair
thinair's Avatar
Depends on who you ask, technically yes, you're wrong. The North American e36 M3 engines aren't real Motorsport engines. They're M50 and M52 based engines. The S50 engine used in the rest of the world is the real Motorsport engine.
If you use a european BMW parts catalog, the NA M3 engine is listed as M50 and M52. I've seen it with my own eyes at a dealer in Portugal.
The 2.5L engines were listed, M50B25 (91-92), and M50B25tu (93-95).
The number after the B is the engine displacement. M50B25 is 2.5L, M52B28 is 2.8L.
Old 01-05-2006, 02:41 AM   #10
Soldo
Soldo's Avatar
M50B20, 320 engine
Can any of these parts be swapped/frankensteined into an engine to make for more power...... like can i put the hotter cams from a non vanos M50 into a vanos one, with the forged crank from a 328?
Keven Soldo
Old 01-05-2006, 02:55 AM   #11
thinair
thinair's Avatar
Non Vanos cams can't be swapped into any other motor
The 3L crank can be swapped into the 2.5L and 2L blocks, the 3.2L crank can be swapped into the 2.8 and 2.5 (323i) blocks.
My dream, if I had too much money would be this, the aluminum 2.8L block (from the Z3, 528, euro 328), 3.2L crank, 3.2L head, proper forged rods, and aluminunm pistons. But financially it would make no sense to do that.
Old 01-05-2006, 09:56 AM   #12
uber e36
uber e36's Avatar
From what I've read, a common setup is:
M52B28
with:
M52B32 cams
with:
M50B25 manifold
Daily: '06 S4
Wife: '05 X5 4.4i
Fun: '95 325is
Old 01-05-2006, 11:21 AM   #13
SickFinga
SickFinga's Avatar
Us spec e36 m3 uses real BMW M GmbH engines.
Not all BMW M GmbH engine are S. A good example is BMW M1 that has M88 engine.
Yes its true though, Us spec spec engines are based on M50/M52 and not all new engine like S50.
Old 01-05-2006, 11:24 AM   #14
SickFinga
SickFinga's Avatar
M50B20, 320 engine
There is also M50B20TU, vanos one.
and Im sure you just made a mistake, M52B25 is a detuned 2.8 engine
Old 01-05-2006, 01:12 PM   #15
thinair
thinair's Avatar
M52B28
with:
M52B32 cams
with:
M50B25 manifold
that is my current setup, with software
no, the M52B25 is a 2.5L engine, it puts out a less power then the M50B25 from the 325/525.
