Old 01-03-2006, 10:03 AM   #1
fukes
fukes's Avatar
OBC Help???
I just did the conversion from 11 button to the 18 Button OBC. Everything works except the "Check Control". It use to work on the 11 Button OBC and was just wondering if anyone else had this problem and what they did to fix it.
Anyone have any Ideas let me know.
fukes is offline   Reply With Quote
Old 01-03-2006, 10:35 AM   #2
98Dinan3
98Dinan3's Avatar
anyone? I'm about to do this swap, If I run into it I'll post results.
Old 01-03-2006, 01:07 PM   #3
fukes
fukes's Avatar
I read somewhere that I might have to get it re coded or something but, I'm not sure what that entails and why I would if it was already working on the old one.
Old 01-03-2006, 05:45 PM   #4
fukes
fukes's Avatar
Its fixed, a wire was pulled out when i was re-wiring the OBC
Old 01-05-2006, 07:20 PM   #5
98Dinan3
98Dinan3's Avatar
how did you find the swap? is it worth doing?
Old 01-06-2006, 08:48 AM   #6
Furious
BMW again.
Furious's Avatar
fukes id like to know if everything on the 18button works, ie. all the extra buttons have function ?
Old 01-09-2006, 06:36 AM   #7
fukes
fukes's Avatar
My car is in my garage for the winter so I'm unable to test everything out, but by the looks of what I can test it works pretty good. I can let you know in the spring when I take it back out if you want.
Old 01-09-2006, 08:13 AM   #8
Justin e36
Justin e36's Avatar
yup, everything will work if your vehicle already has an 11 button.
If you have an 8 button currently, then not everything will work when you do the 18 button conversion.
J
Old 01-09-2006, 01:13 PM   #9
Furious
BMW again.
Furious's Avatar
thnx justin, hmmm i guess it would be fun to have extra CP buttons.
Old 01-09-2006, 10:31 PM   #10
E36ForL!fe
Grabbed Second
Send a message via AIM to E36ForL!fe
Where can you buy an 18 button obc and what extra features does it have?
E36ForL!fe is offline   Reply With Quote
