Old 12-28-2005, 06:02 PM   #1
bmnorm
bmnorm's Avatar
changed clutch and car now feels slower
so I got my clutch changed with a saches upgrade clutch kit.
and now my car feels like it has less pick up.
can this be caused by the clutch being installed incorrectly?
also when I make a hard right turn I can hear something hitting at the bottom. I took the car back to the mechanic everything looked fine, but he tightend the muffler.
but after driving the car I noticed it was still making the same sound when I turn right. and when I turn left I don't hear anything.
is there some kind of trick with the muffler.
oh yeah, I put on 15" snow tires. does the lower rim decreace torque/ pick up?
thanks
bmnorm is offline   Reply With Quote
Old 12-28-2005, 08:47 PM   #2
your snow tires are prolly heavier, it could decrese pickup. Are you judging this using teh butt dyno or your rpms climing? your clutch was prolly slipping before, now it isn't so rpms dont climb as quick
Old 12-29-2005, 01:38 AM   #3
bmnorm
bmnorm's Avatar
I think you are right about both things.
thanks
Old 01-04-2006, 02:36 PM   #4
bmnorm
bmnorm's Avatar
ok, this is going back up.
my car really feels slow.
my mechanic did not change the Pilot Bearing, he said my old one was fine.
also I don't know if he used the alignment tool. is this tool really needed.
would any of this make my car slower.
I have never been in another 328 so I don't really have anything to compare it to.
but it just feels slower.
I trust on my rench, but he doesn't work too much on bmw.
thanks
Old 01-04-2006, 02:55 PM   #5
Hasselhoff
Hasselhoff's Avatar
It's almost always necessary to use one when replacing your clutch. If you don't, the clutch disc will most likely end up misaligned with the pressure plate and flywheel and will chatter like a sumb*tch everytime you disengage the clutch.
As for what could be causing your lack of power... None of what you mentioned would really make your car slower.
Hasselhoff is offline   Reply With Quote
Old 01-04-2006, 05:32 PM   #6
my buddy prohilphic was talkin bout this a couple days ago and he brought up a possible scenario. Your mechanic could've ripped off your lightweight flywheel and replaced it with a dual mass.
on another note, i got a stock 328, 5spd but its a 4dr. we can go for a spirited drive if you like, but my clutch is on its way out, so if im keeping up with you something really is wrong
