Old 12-20-2005, 03:46 PM   #1
What to buy at the dealership (quick question)
Ok i have a credit at my disposal of 1100 bucks at the dealership, and it expires soontimes.
so im planning on buying:
02 IGNITION COIL BREMI 6 12131748018 $83.70
08 SPARK PLUG, HIGH POWER BOSCH FGR7DQP 6 12120141871 $16.63
02 MOULDING DOOR FRONT LEFT M TECHNIC 1 51132262115 $57.47
02 MOULDING DOOR FRONT RIGHT M TECHNIC 1 51132262116 $57.47
15 OXYGEN SENSOR SIEMENS/L=990MM 2 04/1998 11781427884 $195.30
ONLY WITH: -- CABLE HOLDER 4 04/1998 61138365523 $0.28
(Plastic peice for door insert over handle)
12 LEFT CONTROL RAIL 1 54128119095 $30.13
2 ANTIFREEZE 1 GALLON 1 82141467704 $24.55
03 LAMP LENS FOG LAMP LEFT 1 63178357397 $78.96
06 BULB 12V 55W H1 2 63217160777 $8.93
09 SUPPORT LEFT M TECHNIC 1 51112233845 $3.01
09 SUPPORT RIGHT M TECHNIC 1 51112233846 $3.01
01 LEFT PRIMED EL.EXTERIOR HEATABLE MIRROR M TECHNIC 1 51162263979 $232.13
01 RIGHT PRIMED EL.EXTER.HEATABLE MIRROR M TECHNIC 1 51162263980 $232.13
ONLY WITH:
-- SCREW SELF-TAPPING M6X14 Z1 3 51168220001 $3.38
RETROFIT KIT, M DOOR SILL TRIM, PRIMED ? 07/1993 82119403141 $466.49 See EBA 9784667, ABE 9787739
Any other suggestions?
(stuff like ignition coil are obviously just things that are broken)
Old 12-20-2005, 03:47 PM   #2
mirek
mirek's Avatar
credit's dont expire.
Old 12-20-2005, 03:48 PM   #3
well apparently this one does (its a friend of mine's credit at maranellos')
Old 12-20-2005, 03:54 PM   #4
MV325IS
MV325IS's Avatar
Need help spending it? Im really good at that !
92 325IS
|Black on Black|20% tint|
|APA450|APA2001|Smokey Tails|Bilstein Struts & Shocks|H&R Springs|B&M Short Shift|Clear Corners|
|Angel Eyes|AA GEN 3 |MOMO Quick Release|Ireland Engineering Bushings & Shock Mounts|
98 328I
MV325IS is offline   Reply With Quote
Old 12-20-2005, 03:59 PM   #5
lol
anyone know what Rear shock mounts / driver side window regulators are called (or P#)
Old 12-20-2005, 04:08 PM   #6
MV325IS
MV325IS's Avatar
This is what i found for the Rear shock mounts
http://www.realoem.com/bmw/showparts...86&hg=33&fg=45
And this for the window regulator
http://www.realoem.com/bmw/showparts...51&fg=10&hl=35
Hope it helps
92 325IS
98 328I
Old 12-20-2005, 07:24 PM   #7
ended up getting
-pre cat oxygen sensor (211$)
-Antifreeze X2 (52)
-Fog lens (passenger) 143
-Fog bulb(12)
-Window regulator DF(90)
-2 X some sort of blocks for WR (7)
-Shock Mounts, rear X 2 (84)
-M technic mouldings (282)
Total bill: 881$
Not a bad way to spend a paycheck. Now if only i had a source of income
AND phil forgot the ignition coil, which is like 100
so 981
