Old 12-15-2005, 04:06 PM   #1
static
static's Avatar
HID retrofit into my e30
Hey
anyone done it? got pics?
i heard that there was someone on max that had done e39 projectors into e30, but cannot find the post.
Alex
Old 12-15-2005, 06:26 PM   #2
search, limit ur search to the e30 section and you will be amazed
Old 12-15-2005, 08:19 PM   #3
Gamite
Gamite's Avatar
Why don't you just use E30 elipsoids like everyone else, and drop in a plug n play kit. Much easier, and it'll save you muchos dollars.
www.gamite.net
Old 12-15-2005, 08:30 PM   #4
HIDs projectors spread the light better and wider.
Im trying to get my hands on some projectors so i can retrofit them
Old 12-15-2005, 08:33 PM   #5
Gamite
Gamite's Avatar
HID fogs will solve the spread on the sides.
www.gamite.net
Old 12-15-2005, 09:02 PM   #6
static
static's Avatar
1. much better spread
2. no blinding oncoming traffic
3. very nice cutoff = not having to use rice 6k lamps ans at the same time getting nice blue flicker
Old 12-15-2005, 10:28 PM   #7
This man knows what he's doing.
A very good resource for you: http://faqlight.carpassion.info/car-oem-hid.htm
Use that to get an idea of what projectors to use from which car. The dimensions are extremely useful.
Old 12-15-2005, 10:28 PM   #8
No way fogs can light as far and as wide as HID projectors. In reality they only shoot out under 30ft.
Old 12-15-2005, 11:25 PM   #9
Gamite
Gamite's Avatar
well, your low beams are for the distance, the fogs will cover the width. how far away do you have to see to the right or left of you?
static, unless you're gonna put auto leveling, you will blind oncomming traffic just as much as standard elipsoids.
www.gamite.net
Old 12-15-2005, 11:27 PM   #10
Wannabe
Northwood.
Wannabe's Avatar
I am confused.. tell me what this guy is doing!!
and why is retrofitting projectors better then elipsodes?
Current - 2011 Jeep Grand Cherokee Laredo
2010 Jeep Patriot North All-season
2009 Jeep Wrangler Unlimited Sahara
2002 Dodge Durango SXT
1985 BMW 325e
1998 Pontiac Grand Prix GTP
1995 Nissan Altima SE
1994 Mazda MX-6 RS
1984 Buick Riviera
Wannabe is offline   Reply With Quote
Old 12-15-2005, 11:57 PM   #11
If you're turning fast (highway ramps, late track nights) you'll want very distant and wide lighting. Fogs have no purpose outside of fog, don't make them something they aren't and can't be.
Real HID projectors will have less glare (although our halogen housings do have little of it relative to others), and also lack the blinding flare of BMW ellips (minus the US oddities).
Old 12-16-2005, 12:19 AM   #12
static
static's Avatar
Mystikal is correct
Ellipsoids were designed for halogens, i e there is some amount of light that is leaking past the cutoff edge (that somewhat gets into other drivers' eyes) - it is tolerable for halogens but unacceptable for stronger and higher K HID light output. OEM projectors OTOH were designed for HID strength and do much better job in cutting the light
Also as i said already, one doesn't have to go to lower output 5k+ color hids to get blue tint. With real projectors, one gets the bluish edge due to dispersion of light.
Hopefully i will once finish my retro and will show off the result
Alex
Old 12-16-2005, 12:26 AM   #13
Gamite
Gamite's Avatar
us spec elipsoid cut off is pretty good, I don't think there will be much of a difference, as Jay said.
other than the wider beam pattern, I don't see any other benefit. I guess if you can find them at a reasonable price or if you can manage to find bi-xenon it would be more worth it.
will be interesting to compare to stock elipsoids when you're done. let us know.
www.gamite.net
Old 12-18-2005, 12:21 AM   #14
MGYVER
MGYVER's Avatar
HID Retrofit
__________________________________________________ _________
I would have to disagree somewhat with the above statements.
I have done the retrofit into stock ellipsoids, however it wasn't just a simple "plug and play". The secret is to take great care in measuring the focal point of the bulbs. The D2S bulbs are off about 3 millimetres in depth. If you use a dremel and measure VERY accurately you will get excellent results. It takes an extra hour but is well worth the effort.
ie. 1) I have excellent beam spread and distance- can see both shoulders well and very far in front.
2) I have never been 'flashed' for blinding an oncoming driver
3) Good cutoff and I use the 4300K bright white bulbs
Targa Newfoundland - It's about the Drive !
MGYVER is offline   Reply With Quote
Old 12-18-2005, 01:51 AM   #15
Gamite
Gamite's Avatar
There are kits that are made to fit in your stock housings, they have the correct measurements for the stock bulb, so you don't have to do any measurements yourself.
The cut off point he's refering to is the blue haze that comes off the stock HID housings due to the curvature of the elipsoid.
Mgyver, seen your car in front of Ryerson a few months ago, and at charlie's place getting that M50 swap
www.gamite.net
