12-08-2005, 02:05 PM
#1
Car: 1994 325IC
Heater Problem?
My heat comes on okay when driving, however when I stop at a traffic
light, or coasting, it just blows cold air. The heat only comes out when
the engine is under load. Any thoughts? Thermostat? (replaced 2 years
ago) or ??
Thanks,
Ken
94 325IC
12-08-2005, 02:25 PM
#2
Addict
Car: 97 318 IS
Were does the temp gauge stay @ when up to temp. 12 o clock?
If lower then 12 o clockT-stat is shot again.
A coolant flush wouldn't hurt either, part of maintenance every 2 years.
12-08-2005, 03:03 PM
#3
Car: BMW
Try to bleed it..
With the car at running temperature, turn on the hot heat in auxillary key position, unscrew the bleeder screw, open the rad cap, and start pouring water in,.. bubble should come out of the bleeder hole.
or you can do this with the car running and attache a hose to the rad cap and force all the air out..
12-08-2005, 03:27 PM
#4
Car: e36 m42
Most likely your water valve.
Also verify your thermostat is not seized.
12-08-2005, 10:25 PM
#5
Car: 1994 325IC
Jeff, The gauge is right in the middle where it should be. I may try the flush as well and see what happens. Thanks for the input. Ken
12-08-2005, 10:39 PM
#6
Car: 1994 325IC
Justin, Thanks for that info. I will have both checked out. Where did you copy that from? Regards, Ken
12-08-2005, 10:45 PM
#7
Car: 1994 325IC
Thanks everyone for your suggestions. I will post root cause when found. Ken
12-08-2005, 11:44 PM
#8
JUICY J CAN'T
Car: S54 titties
He copied that from the BMW tis.
if you need it contact me
12-09-2005, 01:00 AM
#9
Car: unknown
great info Justin! had same problem, will try to see if this will fix it...
