Old 12-08-2005, 01:13 AM   #1
XI JR IX
1st BMW
Send a message via MSN to XI JR IX
Car Audio FS: 1 JL e1200 Amp + 1 JL 10w0 w/ Sealed RoxBox
Hey Guys,
This was part of my old system that I only had for a few months and then decided to upgrade. Everything is pretty much brand new, no scratches on the amp or sub. I've got the full boxes for both the amp and sub. If you are interested reply or pm me. I don't have pictures yet but I can get them this weekend if you want. I've also got a Alpine CDA9811 if anyone wants to make me an offer on that.
-- $500 CDN -- (Or Best Offer)
| JL Audio e1200 Class A/B Monoblock Full-Range Amplifier |
General Specifications:
Rated Power (mono):
120 W RMS x 1 @ 4 ohm (12.5V)
200 W RMS x 1 @ 2 ohm (12.5V)
THD at Rated Power:
104 dB referred to rated power (A-weighted, 20 Hz – 20 kHz noise bandwidth)
Frequency Response:
10 Hz – 25 kHz (+0, -1dB)
Damping Factor:
>200 @ 4 ohm / 50 Hz
>100 @ 2 ohm / 50 Hz
Slew Rate:
± 22V/µs
Input Range:
200mV – 8V RMS
Dimensions:
9.8" x 9.25" x 2.36"
Absolute Symmetry™ Class AB Circuit (U.S. Patent #6,294,959)
Differential, Noise-Cancelling Input Topology:
RCA jack inputs (low-level) and multi-pin jack (high-level)
On-board Crossover:
State-variable, 12dB/octave Butterworth with continuously variable cutoff frequency selection from 50 – 200 Hz. Configurable as Low-Pass or High-Pass
Preamp Output:
Pass-through type.
Speaker output connections:
accept up to 8 AWG wire
+12V and Ground connections:
accept up to 4 AWG wire
http://mobile.jlaudio.com/products_amps.php?amp_id=257
| JL Audio 10w0 10" Subwoofer |
Nominal Diameter: 10 inches (250 mm)
Continuous Power Handling: 125 Watts
Voice Coil: 1.38" diameter, 6-layer, Kapton former
Available Configurations: 4 ohm or 8 ohm (Single Voice Coil)
Xmax (one-way, linear): 0.34" (8.6 mm)
Sealed Enclosure Range: 0.50-0.90 cu.ft. (14.0-25.5 liters)
Ported Enclosure Range: 0.90-1.50 cu.ft. (25.5-42.5 liters)
VRCÃ?Â? Technology: YES
XI JR IX is offline   Reply With Quote
Old 12-08-2005, 01:46 AM   #2
BMWFORLIFE
Technoviolet Shifting
will this fit in a convertible trunk
BMWFORLIFE is offline   Reply With Quote
Old 12-08-2005, 01:57 AM   #3
kontesto
Send a message via ICQ to kontesto Send a message via AIM to kontesto
If its just the 1 10" sub I would assume so.
KaM
KONTESTO
2001 Audi A4 1.8T
kontesto is offline   Reply With Quote
Old 12-08-2005, 02:02 AM   #4
XI JR IX
1st BMW
What dimensions are you working with??
This system would be awesome in a convertible. I had it in a hatch and it pounded.
Old 12-08-2005, 08:01 PM   #5
XI JR IX
1st BMW
bump...
??? $400 CDN ???
Old 12-14-2005, 02:26 AM   #6
XI JR IX
1st BMW
Here are the pics..
The Dimensions of the Box are:
Width - 25 3/4 inches
Height - 13.2 inches
Depth - 12 inches (1ft)
Old 12-17-2005, 12:26 AM   #7
XI JR IX
1st BMW
bump.. Price Drop!
** $350 **
Old 12-17-2005, 07:50 PM   #8
BMWFORLIFE
ill take it for 300 right now
Old 12-17-2005, 09:42 PM   #9
XI JR IX
1st BMW
PM sent.
Old 12-20-2005, 10:26 AM   #10
XI JR IX
1st BMW
Both Items Still Available.
Old 12-22-2005, 12:46 PM   #11
XI JR IX
1st BMW
** All Items have been sold **
Thanks for the interest.
