Old 12-06-2005, 04:40 PM   #1
Euro_E30
Euro_E30's Avatar
Super ETA???
Anyone have any information about this motor? im rebuilding one right now, and i want know if there any upgrades i can do it while its apart. is the bottom end really as strong as people say?
Euro_E30 is offline   Reply With Quote
Old 12-06-2005, 04:43 PM   #2
jeremy
put an "i" head on it..
Old 12-06-2005, 04:58 PM   #3
JazzM
The i head route seems to be the best route to go. Also bumping up the compression a bit won't hurt it either (thinner gasket and/or shaved head).
You may want to PnP the head as well while you're at it.
T.
T.
Old 12-06-2005, 05:23 PM   #4
The Super ETA has an "I" head! Its other parts that are not the same as the "I" motor; TB, FPR, ECU, injectors....
Old 12-06-2005, 05:24 PM   #5
The Sly
The Sly's Avatar
Yeap
Put everything from a "i" head up to the throttle body...
I would really recommend to shave the head 20thou to be sure it is good and it will get you a bit more compression since the Super ETA pistons suffers from lower compression"8.5 to 1 " compare to 8.8 to 1 on the i engine.
AS for the bottom end, replace all crank and connectiong rods bearings..up to the piston rings.
And yes it is strong, i drive mine to 7000rpm all day long.
The Sly is offline   Reply With Quote
Old 12-06-2005, 05:34 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Doesn't the superETA head come with the standard ETA camshaft? If it does an "i" cam is an upgrade.
Old 12-06-2005, 06:05 PM   #7
paul christians
87325is///MR.EVIL
you, may need to do something with pistons releaf cuts, if you go with the I head...
87is325///2.7L..EVIL.....
Old 12-06-2005, 06:42 PM   #8
The Sly
The Sly's Avatar
No Paul you don't need too if you only shave 20thou...
believe me i know ...i shaved a i head 1.5mm with lots of work in the bowls and put it on a Super ETA block and it was working fine but the valves were very close to the pistons..
Old 12-06-2005, 06:46 PM   #9
paul christians
87325is///MR.EVIL
sweet..
that is cool, but I thought you had to do that, if not that is cool thax..
Old 12-06-2005, 07:18 PM   #10
Literally just find an entire i head and throw it on.
Or, read Fred Kim's site: http://www.strictlyeta.net/
Old 12-06-2005, 10:06 PM   #11
MR 325
R3VLimited.com
Send a message via AIM to MR 325
Along with the i wiring harness, ecu, and injection
MR 325 is offline   Reply With Quote
Old 12-06-2005, 10:13 PM   #12
Euro_E30
Euro_E30's Avatar
sweet thanks alot guys! it already has an i head on it. and im trying to lower compression as much as possible because i plan to boost this motor.
but yeah thanks again for the info !
Old 12-06-2005, 11:14 PM   #13
arsevader
The only thing 'i' about the 1988 'super eta' head is the casting. Everything else is low end. Single valve springs etc.
James
arsevader is offline   Reply With Quote
Old 12-07-2005, 02:45 AM   #14
Then just use a normal ETA bottom end, its that simple! Your compression will be lower, perfect for boost!!! Let me know next time so i keep one for you, i just got rid of 2 of those!
Old 12-07-2005, 10:08 AM   #15
Woofer
Woofer's Avatar
i still have mine if you really want it. It's in the car.
