Old 12-05-2005, 07:18 PM   #1
e30_kid89
The Afro-stig
e30_kid89's Avatar
Rear hub & axle nut
im gonna have to be removing the rear hub in order to replace the left rear backing plate....but i dont wanna start it knowing anything needs to be replaced...does any body kno or can any body tell me if ne of these parts need to be replaced or wen im done changing the plate i can just stick everything back on there?
Old 12-05-2005, 07:56 PM   #2
Jordan
You will destroy the wheel bearing when you remove the hub. You will need a new wheel bearing.
You will need a new nut, and locking plate.
You will need special tools to remove the hub assemby, to drive out the halfshaft, and to install the hub assemby without destroying the new wheel bearing.
This really is not a DIY job.
Bend your backing plate so it isn't hitting anything, and live with it.
Old 12-05-2005, 08:15 PM   #3
e30_kid89
The Afro-stig
e30_kid89's Avatar
****......the previous owner told me it was because of the backing plate that the ebrakes werent working.....wen i took a look i seen the acutator was actually damaged and i have a gut feeling the plate doesnt really have anything to do with the ebrake unless the holes to put in the springs r rusted out and bigger than they need to be. im going to try to put on the all the ebrake parts since i took em all off and see where to go from there. thanks for the warning jordan lol
