Old 12-01-2005, 01:51 AM   #1
JUICY J CAN'T
propr'one's Avatar
ICV in e36 6cyl
Where exactly is it? anyone got a pic?
I want to clean mine cause i replaced my o2 sensors and idle is still a little shakey (between 400-650 rpm)
its probably a good idea to clean it anyway
hid headlights
Old 12-01-2005, 02:04 AM   #2
thinair
moderationistismingly
thinair's Avatar
Send a message via ICQ to thinair Send a message via MSN to thinair
It's right under the intake manifold. Reach under the throttle body, under the manifold you'll feel a 1" thick tube, the other end leads to the ICV. It's in a pretty hard to reach location.
Basically remove your airflow meter, the airbox if you have one, and the throttle body boot. That'll get you some more space to work with. It's a cylinder shape, two hoses going into it, and a plug on the other end.
I'm sure someone will post of pic of one.
Old 12-01-2005, 02:36 AM   #3
JUICY J CAN'T
propr'one's Avatar
Cool, i'll probably do this in the AM then, but a pic would be great. thanks as always nelson!
hid headlights
Old 12-01-2005, 12:08 PM   #4
///MP
Purveyor of Useless Info
///MP's Avatar
#6
And it will look something like:
Credit to original poster on bf.c
///MP is offline   Reply With Quote
Old 12-01-2005, 03:51 PM   #5
JUICY J CAN'T
propr'one's Avatar
Ok, ima look for it, im still not sure exactly where in the car it is, but i'll try to follow nelson's instructions.
(if i pull out my alternator and the car wont work anymore i may need some towing)
hid headlights
Old 12-01-2005, 04:09 PM   #6
thinair
thinair's Avatar
You don't need to pull the alternator.
The throttle body rubber elbow has a fat hose coming out the bottom, follow that under the manifold and it will lead you to the ICV.
Old 12-01-2005, 05:25 PM   #7
JUICY J CAN'T
propr'one's Avatar
thinair: I was joking man, i meant if i pull the wrong thing out aka accidentally pull out my alternator
hid headlights
Old 12-01-2005, 10:55 PM   #8
PedroBMW
Hooked on Boost
PedroBMW's Avatar
Its a ****ing pain to get to on my 325is i had. But well worth the time to clean it. My cars idle was rock solid after.
