Old 11-25-2005, 09:22 PM   #1
Jordan
All about my heavily modified m20 head.
Everyone seems to be interested as I'm constantly asked about what I'm doing with it and for pictures etc.
I haven't really showed much of it till now.
What I've done:
Intake ports enlarged slightly to gasket size.
Intake ports heavily ported.
Intake valve guides reduced/smoothed.
Intake bowls heavily worked and smoothed.
Intake valve guide transition knifed.
Exhaust ports greatly enlarged to match gasket size.
Exhaust ports heavily ported.
Exhaust valve guides reduced/smoothed.
Exhaust bowls heavily worked and smoothed.
Combustion chambers recontoured/detextured.
Combustion chamber flycut smooth transitioned.
Combustion chamber removed valve shrouding.
Whats still left to be done:
Combustion chambers polished to a mirror finish.
Exhaust ports minor touchups.
3 angle valve grind.
Resurface sealing surface of head.
Assemble and install!
Head, intake ports:
http://jordan.lodac.com/Images/112505-001.jpg
Head, exhaust ports:
http://jordan.lodac.com/Images/112505-002.jpg
Intake port, closeup:
http://jordan.lodac.com/Images/112505-003.jpg
Exhaust port, closeup:
http://jordan.lodac.com/Images/112505-004.jpg
Chamber close up:
http://jordan.lodac.com/Images/CC.jpg
Also, here is a stock 885 chamber to compare:
http://jordan.lodac.com/Images/CCREF.jpg
Headers/catless midpipes:
http://jordan.lodac.com/Images/Headers.jpg
I will be installing this with my ceramic coated headers, catless midpipes, and with a oil seperation system to keep oily crankcase vapors from entering the intake. I will be installing my rocker arms, rocker shafts, and cam from my current head into this one. Valves, springs, retainers, keepers, etc will be OEM.
Old 11-26-2005, 03:20 PM   #2
paul christians
87325is///MR.EVIL
That looks good too me. Jordan do you use as a mirror??hehe..I know that is what is needed the setup..JJ..
87is325///2.7L..EVIL.....
Old 11-26-2005, 09:04 PM   #3
Three questions for ya Jordan.
First, you say you're using stock valves. Ok. But how much are you really gaining if you port it, yet retain stock valves? Is there bigger intake valves available? Is that the reason you stuck to OEM? just curious....
Second... you also say stock valve springs. And you rev to 7100rpm I believe? How much can stock springs go to before the valves start floating?
Lastly, what rocker arms are you using?
Thanks dude
Old 11-26-2005, 09:28 PM   #4
Jordan
You obviously don't know anything about valves and airflow. I'm NOT going into it here as its far over everyones head. All you need to know is running a +4mm intake valve would give me a 1%HP gain, and cost thousands of dollars in headwork that I cannot do.
Stock springs will float valves at 7100rpm. My current redline is set to 6900rpm. Perfectly fine there.
Brand new stock rocker arms.
Old 11-26-2005, 09:48 PM   #5
No, obviously I don't. I am 17 Jordan. I am here to learn hence why I am asking questions....
Old 11-26-2005, 10:09 PM   #6
ZiMMie
that head should flow very nice.
wat tools did u use for enlarging the port? Dremel?
#E36-S54 #CSLWannabe
Old 11-26-2005, 10:35 PM   #7
Jordan
I'm sorry. I didn't mean for it to come off in that manner.
Standard Abrasives Deluxe porting kit. Absolute must for this job. (same exact kit pros use)
Requires a good strait die grinder and an adjustable pressure regulator.
Dremel's are NOT suitable for this task. You will destroy the bearings and overheat them.
Old 11-26-2005, 10:38 PM   #8
ZiMMie
those looks lke bits. wat drives these things.
*edt* never mind. now i need to find my self an electric grider with a 1/4" collet
Old 11-26-2005, 11:33 PM   #9
Jordan
Electric grinders will also overheat quickly. Die grinders rock because they are cooled by the constant cool air driving them.
Old 11-27-2005, 12:45 AM   #10
ZiMMie
will a RotoZip work?
Old 11-27-2005, 12:55 AM   #11
Jordan
No.
Old 11-27-2005, 01:58 AM   #12
where can i get a kit like that
Old 11-27-2005, 02:57 AM   #13
paul christians
87325is///MR.EVIL
But, you need to know what you are doing for this, if not you are soo ****ed.....And bye..bye head..I did the head civic back in the day..
Old 11-27-2005, 10:36 AM   #14
Jordan
I bought mine from www.summitracing.com
As Paul said though, you need to know what you are doing and where you can and cannot remove material. While the overall process is easy enough, if done without care it can turn the head into a large paperweight.
Old 11-27-2005, 11:29 AM   #15
JazzM
All in all how much did it end up costing? With all new parts, equipment, etc... not counting labour of course.
BTW, are you going to put a different cam in there? schrick?
T.
T.
