Old 11-24-2005, 10:45 PM   #1
mirek
mirek's Avatar
wider tires in the rear bad for winter?
i'm running 225/45/17 on the front and 235/45/17 on the rear.... is that gunna affect my handling that much?
Old 11-24-2005, 11:00 PM   #2
Justin e36
Justin e36's Avatar
YES, it will affect handling A LOT. I learned the difference mighty quick with my 255's on the back.
wider tires can't cut through the snow as easily and rides on top instead... (like ski's). I gave up a set of 225 blizzaks and are going for 205 instead.
Old 11-24-2005, 11:09 PM   #3
mirek
mirek's Avatar
oh well, i guess i'll just call and add full insurance to my car just incase.
Old 11-24-2005, 11:32 PM   #4
Storamin
Storamin's Avatar
much cheaper to purchase some 205 tires w/ rims than replacing the whole car... much more relaxing to drive in the winter, too.
Storamin is offline   Reply With Quote
Old 11-24-2005, 11:39 PM   #5
rico328i
Are they 'winter' tires you're running? Either way....those are quite wide. Not adviseable. I dropped down to 215/55/16 'winters'.
Old 11-24-2005, 11:44 PM   #6
mirek
mirek's Avatar
m3's run 235 45 as winters..
and yeah, they're Pirelli Winters from the dealership
Old 11-25-2005, 10:30 AM   #7
///MP
Purveyor of Useless Info
///MP's Avatar
As a skier I drive up to Quebec and Collingwood several times during the winter, so I have a lot of experience with this. I've been running those exact sizes on my e36 M3 for a couple years now (w/ Pirelli Snowsport 210) with NO MAJOR PROBLEMS! Yes, in deep snow you have to work a bit more, but it's nothing you can't handle. On the slush and hard pack snow it's just as good as my Accord was on its 195/60R15's. And in the dry, you can't beat a nice wide tire.
That being said, I bought the tires to fit the stock 7.5"F/8.5"R wheels. If you have the chance to pick up some 16x7 rims and run 215 wide tires then go for it. Narrower tires will handle better in deep snow, no doubt. Whatever you do, make sure you go to an empty (snow covered) parking lot and practice skid recovery and all that other fun stuff. Just learn your limitations and then try not to exceed them.
MP
///MP is offline   Reply With Quote
Old 11-25-2005, 10:35 AM   #8
mirek
mirek's Avatar
MP
Thanks bud, that's EXACTLY what i wanted to hear. I will be doing city driving, in Pirelli Snowsport 210's 225/45/17 front, 235/45/17 rear, on my contours.. Thanks again... i'll have the nicest winter setup
Old 11-25-2005, 10:42 AM   #9
///MP
///MP's Avatar
Are the rims staggered Mirek?
MP
Old 11-25-2005, 12:44 PM   #10
mirek
mirek's Avatar
MP
no, but the 235's were the only wheels i could find.
Old 11-25-2005, 02:17 PM   #11
chitown
I'm running 225/50R16 all-seasons, looking to buy winters in a couple days, should I be getting something smaller? What's a recommended size for me?
chitown is offline   Reply With Quote
Old 11-25-2005, 02:31 PM   #12
///MP
///MP's Avatar
That means your Contours are 7.5" wide right? 235's fit on there OK? Like I said, I only went staggered to fit my wheels. Try to find some 225's for your rears and dump the 235's. It's no big deal, but you may find it a bit more balanced in the snow.
Old 11-25-2005, 02:48 PM   #13
///MP
///MP's Avatar
You've got a 328is right? 215/55R16 will fit your stock rims fine. Your speedo will be off slightly because they're just a bit bigger than what you're running now (215/50R16 is actually closer, but don't bother even looking for that odd size!). The 205/55R16 should fit your rim (7" wide...right?) and it won't affect your speedo reading! Plus as mentioned, narrower is better in snow. So, your choices are:
215/55R16
205/55R16
It might be rough (at this busy time of year) finding the brand of tire you want, so take either size you can find.
MP
Old 11-25-2005, 04:57 PM   #14
RumRogerz
RumRogerz's Avatar
well just look at it logically
the more surface you're tires have, they more snow and slippery stuff it's gonna come in contact with. So you might not want that.
Always and never are two words you should always remember never to use
RumRogerz is offline   Reply With Quote
Old 11-25-2005, 05:03 PM   #15
chitown
///MP - thanks a lot
