Old 11-21-2005, 08:59 AM   #31
Darkness95m3
Darkness95m3's Avatar
Originally Posted by ///MAC
from what ive known and heard from many Hi Fi stores they have told us to stay away from DLP as the bulb is very expensive after it blows, LCD is going to be gone in a few years or so, and plasma is really the only good option right now. If you dont have the cash, and depending on the size they told us to get a pineer rear projection tv. Best in the business, but since flat panel i would go plasma wouldnt go any other way. You should go to audio excellence on baview and hightech, or inside times square there is a Hi fi store, the guys name in there is emil, nice guy and tells u stright up.
Shop around you will find different stores will give you different opinions.
Plasma is the way to go if you require 42" or bigger.
Old 11-21-2005, 10:48 AM   #32
dozorca
Wait for SED
Plasma SED - LCD
SED - Surface-conduction Electron-emitter Display - which is a new type of screening technology. The specs are simply stunning - 1ms response time, 100000:1 contrast ratio and 1920x1080 resolution. It will probably rival OLED as the successor to Plasma and LCD screens. Verdict of hardware.fr, this technology performs much better than anything they've seen until now.
SED (Super-conduction Electron-emitter Display) technology developed by Canon and Toshiba. Yesterday, Robert Franner and I had an opportunity to attend a closed-door briefing and demonstration of the new technology.
The demonstration featured a side-by-side comparison of 37-inch plasma, LCD and prototype SED displays, all with 720p resolution. The demonstrators would not say which plasma display they were using; the LCD was a current Toshiba model. The plasma is a current model, and according to the presenters, an upmarket unit (as evidenced by the fact that it’s a high-def display). Still, based on its black performance, I would say I’ve seen better plasma displays, though it was clearly much better than the milky-grey units that were the norm a couple of years ago.
Flat-Out Beautiful: In every respect, the SED unit outperformed the plasma and LCD displays. The differences weren’t massive on scenes consisting mainly of mid-tones. But on very dark and very bright scenes, the SED display was far better. On dark scenes, blacks looked truly black; and moreover shadow detail was considerably better, allowing you to make out textures and details in dark fabrics for example. It was the same at the upper end of the brightness scale: more brilliant whites and better highlight detail. Motion was much better on the SED. Especially on the LCD, a sweeping metronome had noticeable blurring: it was completely clean on the SED.
Contrast and motion looked every bit as good as you’d get from a top-notch CRT, which isn’t surprising when you consider that the front surface of the SED display is basically the same as a large, high-resolution picture tube. Like a CRT, SED produces images by firing electrons at a screen coated with light-emitting phosphors. The difference is the source of those electrons. Instead of firing electrons from an electron gun and controlling their direction with an electromagnetic yoke, SEDs have a tiny solid-state electron emitter behind each pixel. The result is a very thin profile. The panel itself is only 2mm deep, and the entire display is 7mm deep.
In a nutshell, this was the best-looking flat-panel image that I’ve ever seen (though some of the new LCD models from BenQ, LG and Samsung that I’ve seen here also look stunning). Given that, I’m not surprised that SED’s developers are hoping to take a 20 to 30% share of the global flat-panel market.
But it’s not going to happen quickly. Toshiba and Canon plan to begin producing a 50-inch-plus 1080p SED television later this year, but at low production volumes, around 3,000 units per month. Once full-scale production begins, capacity will increase to 15,000 units per month, gradually increasing to 70,000 per month by the end of 2007. To put those numbers into perspective, consider that among plasma manufacturers, Pioneer alone is currently producing 100,000 units a month. And while production ramps up, LCD and plasma manufacturers will continue to improve their products. The improvement in these displays in the past year underlines the fact that SED developers are chasing a moving target, so a 25% marketshare isn’t going to fall into their lap – even if they meet their production targets.
There’s no question though that SED is a fabulous technology, and demonstrates that this is a great time to be in the technology business. And it’s a great time to be a technology consumer.
dozorca is offline   Reply With Quote
