Old 11-15-2005, 02:10 AM   #1
Jim .E.
E90 n00b
Jim .E.'s Avatar
DC++ Issue need help
k so im behind a router (SMC p.o.s.), i cant receive any files lists, do searchs or download files...says some stuff for Active IP and tcp/udp port...do i have to go into my NAT and add the port...
jus need some Punjabi tunes from there as they always have em first...LimeWire takes forever to get albums/songs
Old 11-15-2005, 02:16 AM   #2
Jim .E.
E90 n00b
Jim .E.'s Avatar
BTW the NAT has the following stuff:
Trigger Port (Range xxxx-xxxx)
Trigger Type (TCP/UDP/Both)
Incoming Ports (Range xxxx-xxxx)
Data type (TCP/UDP/Both)
Enable/Disable
right now i have BT:
6881-6999
Both
10000-60000
Both
enable
also wtf is DMZ? right now its enabled to the ip 192.168.2.101
i tried setting the active ip to:
65.49.149.102 (host ip)
192.168.2.1 (router ip)
192.168.2.101 (DMZ ip)
...still nada
Old 11-15-2005, 03:00 AM   #3
teh sux0r
Old 11-15-2005, 09:31 AM   #4
Harry
what is the ip of your local machine? the DMZ (demilitarized zone) puts your machine in front of the router. So in your case, the machine with ip 192.168.2.101 is not being firewalled at all.
Have you checked to see if you sp2 firewall is blocking anything? You can also run netstat -a in the command prompt to see what ports are listetning for connections on your local machine.
Harry is offline   Reply With Quote
Old 11-15-2005, 05:20 PM   #5
Jim .E.
E90 n00b
Jim .E.'s Avatar
Proto Local Address Foreign Address State
TCP jim2:epmap jim2:0 LISTENING
TCP jim2:microsoft-ds jim2:0 LISTENING
TCP jim2:4446 jim2:0 LISTENING
TCP jim2:4448 jim2:0 LISTENING
TCP jim2:8981 jim2:0 LISTENING
TCP jim2:1025 localhost:32000 ESTABLISHED
TCP jim2:1026 localhost:32001 ESTABLISHED
TCP jim2:1027 jim2:0 LISTENING
TCP jim2:32000 jim2:0 LISTENING
TCP jim2:32000 localhost:1025 ESTABLISHED
TCP jim2:32001 jim2:0 LISTENING
TCP jim2:32001 localhost:1026 ESTABLISHED
TCP jim2:netbios-ssn jim2:0 LISTENING
TCP jim2:1465 baym2-cs85.messenger.hotmail.com:1863 ESTABLISHED
TCP jim2:1663 uvox1-nye-slot3l.stream.aol.com:5190 ESTABLISHED
TCP jim2:1680 207.68.178.61:http ESTABLISHED
TCP jim2:1685 207.68.178.61:http ESTABLISHED
TCP jim2:1686 baym-sb7.msgr.hotmail.com:1863 ESTABLISHED
TCP jim2:1691 147.46.24.58:50277 ESTABLISHED
TCP jim2:1693 203.229.167.200:50276 ESTABLISHED
UDP jim2:microsoft-ds *:*
UDP jim2:isakmp *:*
UDP jim2:1028 *:*
UDP jim2:1179 *:*
UDP jim2:1373 *:*
UDP jim2:1380 *:*
UDP jim2:1471 *:*
UDP jim2:4500 *:*
UDP jim2:8981 *:*
UDP jim2:ntp *:*
UDP jim2:1034 *:*
UDP jim2:1040 *:*
UDP jim2:1462 *:*
UDP jim2:1900 *:*
UDP jim2:discard *:*
UDP jim2:ntp *:*
UDP jim2:netbios-ns *:*
UDP jim2:netbios-dgm *:*
UDP jim2:1900 *:*
UDP jim2:64244 *:*
Old 11-15-2005, 05:44 PM   #6
Harry
whats your local IP?
Whats ports are you trying to use for DC++?
Old 11-15-2005, 06:08 PM   #7
Jim .E.
E90 n00b
Jim .E.'s Avatar
local ip as in host ip? or the one that my desktop is running on?
host ip: 65.49.149.102
desktop ip: 192.168.2.125
i have no ports setup right now (tcp/udp), wondering what i should use
Old 11-15-2005, 06:28 PM   #8
Harry
you need to open up the ports on your firewall to forward to your local ip 192.168.2.125. whatever ports are required for dc++.
