Old 11-14-2005, 10:21 PM   #1
JaysBimmer
How much to replace headgasket?
I'm looking at a 1991 535, thats needs a headgasket replaced. How much would a shop charge for something like this?
Or is it something I could do myself with the shop manual? Shouldnt be that hard to remove the head.
JaysBimmer is offline   Reply With Quote
Old 11-15-2005, 01:11 AM   #2
Denis
head may need refinishing...
, not only the gasket replacement.
This job can be done even in driveway, the only special tool you will need is a torque wrench. Do not forget to read about how to properly tighten the bolts and when removing the head untight them in the reverse order!
Good luck.
floor right foot
Denis is offline   Reply With Quote
Old 11-17-2005, 06:27 PM   #3
Fern
Fern's Avatar
Why is the headgasket being replaced? Overheated engine?
If so, you may be in for plaining the head also and thats not something you can do in your driveway...
A friend of mine once thought he could change his clutch in his driveway, long story short, cost him 2x as much to have car towed to mechanic and done right there.
Exmodeldater :-)
'99 BMW 540i6 (black on black)
'99 Lexus Rx300
Fern is offline   Reply With Quote
Old 11-19-2005, 08:58 AM   #4
Darkness95m3
Darkness95m3's Avatar
Worst case senario $5,000
Best case senario $1,600
Old 11-29-2005, 10:58 AM   #5
cisco911
i believe my mechanic would do something like just a gasket for 1200 to 1600, depending on little extras that might be needed. However, a car that old would probably need a valve job, so you should look at around $2000 if nothing major is wrong with it, such a heavy overheating that warps or cracked the head.
Old 12-04-2005, 11:40 PM   #6
RMPMOTORS
RMPMOTORS's Avatar
All the quotes above seem a little steep. We at RMP MOTORS would do the job for less. I am a licenced mecanic and an EX BMW dealer certified and factory trained tech.
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
