Old 11-06-2005, 11:48 PM   #1
Traction control
My ASC+T light (the one that turns on when you turn asc+t off) turned on today on the highway. Pushing the ASC+T button did nothing. When i restarted the car it fixed. It happened again eventually though. Idea's?
Old 11-07-2005, 09:57 AM   #2
Justin e36
Justin e36's Avatar
one of your wheel sensors is dying, or one of your tires is worn more than the others.
Old 11-07-2005, 10:10 AM   #3
SickFinga
SickFinga's Avatar
that would trigger ABS light too.
Maybe your ASC relay needs a replacing?
Old 11-07-2005, 10:54 AM   #4
Justin e36
Justin e36's Avatar
Not always. Sam on this forum (don't know his username on here though), had this problem. Checked relays, no luck. I gave him a new computer to try out, no luck. Turned out to be one of wheel sensors was intermittent. It tested as working with the VU meter, but he replaced it anyway---and that fixed the problem. But you're right, it would be much easier to check out the relay under the hood first. I think I have a few extra ASC and ABS relays kicking around somewhere too.
Old 11-07-2005, 10:56 PM   #5
Is there a writeup somewhere on how to check if it is the relay? Especially since its winter i really want my asc+t to work 100%
Old 11-08-2005, 12:07 AM   #6
98Dinan3
98Dinan3's Avatar
yep wheel sensor starting to go. had the same thing. Started as asc, then became asc and abs lights.
Old 11-08-2005, 02:35 AM   #7
How much is it to repair a wheel sensor?
Old 11-08-2005, 08:55 AM   #8
Justin e36
Justin e36's Avatar
finding out if its the relay is simple. the relay is in your fuse box, the orange one is ASC and the red one is ABS. You can test them with a volt meter, or try swapping them with someone else's.
Replacing the wheel sensor will run you around $70-$90 for a used one by my estimation. (going by standard labour costs.) You can do it yourself relatively easily though.
Old 11-08-2005, 10:23 AM   #9
98Dinan3
98Dinan3's Avatar
new wheel sensor cost me $120 at Cross Avenue.
Old 11-10-2005, 11:15 PM   #10
PedroBMW
Hooked on Boost
PedroBMW's Avatar
Yeah its a wheel sensor, mine is the same.
Old 11-20-2005, 09:13 PM   #11
controlyar
This happened to me today. My car was repaired from a small accident about a week ago and is now showing this problem.
The highbeams flashed when the lights came (ASC and ABS) on ? Is that normal - maybe trying to warn oncoming traffic
Its a 2000 328Ci.
controlyar is offline   Reply With Quote
Old 11-20-2005, 09:26 PM   #12
Justin e36
Justin e36's Avatar
highbeams should not flash... ? they only flashed once? or repeatedly?
Old 11-21-2005, 03:24 PM   #13
Storamin
Storamin's Avatar
if your highbeams flashed, it sounds like a problem in your electrical circuit.
Storamin is offline   Reply With Quote
Old 11-21-2005, 03:57 PM   #14
what would you guys recommend i do, this problem has not reoccured since i originally posted. Should I proceed in trying to find what the problem is or just hope it doesn't come back?
Old 11-21-2005, 04:00 PM   #15
MV325IS
MV325IS's Avatar
!! Fix The Sunroof !!
92 325IS
|Black on Black|20% tint|
|APA450|APA2001|Smokey Tails|Bilstein Struts & Shocks|H&R Springs|B&M Short Shift|Clear Corners|
|Angel Eyes|AA GEN 3 |MOMO Quick Release|Ireland Engineering Bushings & Shock Mounts|
98 328I
MV325IS is offline   Reply With Quote
