Old 11-07-2005, 12:08 PM   #16
Very cool, i'll pay charlie a visit sometime soon
Old 11-07-2005, 01:06 PM   #17
BennyL
7th Gear Member
BennyL's Avatar
yes... i think perhaps charlie may be able to help me with my new found love for bimmers.
where is bimmersport?
Old 11-07-2005, 01:48 PM   #18
Justin e36
Justin e36's Avatar
1765 Shawson Dr, Unit 13
Mississauga, ON
905-670-9200 or 416-823-2BMW
Tell him I gave you his # if he asks any. Charlie's a good guy.
Old 11-07-2005, 02:12 PM   #19
BennyL
7th Gear Member
BennyL's Avatar
that's near Dixie and Burnamthorpe, right?
Old 11-07-2005, 02:21 PM   #20
Justin e36
Justin e36's Avatar
Not too far... off of Dixie. Burnamthorpe is at the bottom right of this map:
Old 11-07-2005, 09:49 PM   #21
M3ti Compact
Fuel Efficient 318 Member
M3ti Compact's Avatar
Don't rely on that indicator for oil changes. I've heard that they will go up to 30,000kms before asking you to change the oil- at most every 5-6000kms if you want to keep your car for a long time.
Old 11-11-2005, 12:47 PM   #22
BennyL
7th Gear Member
BennyL's Avatar
ok, help me out here guys. the previous owner didn't leave a sticker for me on the windshield with the last oil change OR the oil type.
so i'm going to do an oil change right away.
problem is, what oil should i use?
Old 11-11-2005, 01:04 PM   #23
Justin e36
Justin e36's Avatar
Castrol Syntec ... go with a winter formula like 5w30.
Old 11-11-2005, 02:15 PM   #24
i use this synthese stuff from germany, its lik 0 W 30 i think
Old 11-11-2005, 04:05 PM   #25
BennyL
7th Gear Member
BennyL's Avatar
is it true that its best to keep using the same oil all the time... as in, always do an oil change with the same stuff you used previously?
Old 11-11-2005, 05:07 PM   #26
Justin e36
Justin e36's Avatar
yes, it is better to keep with the same brand / formula.
if you want to do a complete oil change, you can always do a flush before you put your new oil in. But keep in mind that a flush can also strip any oil that is protecting your seals on older engines.
Old 11-13-2005, 06:47 PM   #27
BennyL
7th Gear Member
BennyL's Avatar
i checked out the owner's manual.
recommended:
5W-30 for cold weather
15W-40 for hot weather
but then it says special oils are most preferred, and to contact the BMW dealer for more info on that.
i have a few cases of 5W-50 full synthetic. should i just use that? i don't know shit all about oil. maybe I'll just ask the dealership what they recommend. i dunno...
Old 11-13-2005, 09:34 PM   #28
Justin e36
Justin e36's Avatar
5w-50... I think only Castrol Syntec makes that.
It's good.. I used it last winter. A little rough in very very cold weather.. but overall did the job.
Old 11-14-2005, 04:09 PM   #29
euro*
euro*'s Avatar
Originally Posted by thinair
I usually just toss a paper clip from pin 7 to 19, turn the ignition to the on position for a bit, then turn it off, remove the clip and turn the ignition back on and everything is clear.
this would also apply for obd1 e36 too right?
euro* is offline   Reply With Quote
Old 02-24-2007, 01:06 PM   #30
COOZE
COOZE's Avatar
Hey Guys first post. I just use a volt tester to do my oil light. Take a look down from the computer port. You will see a bolt sticking out of the fender well. Clip the alligator clip to that, then with the ignition set to accessory stick the tester end in # pin for 3- 7 sec. You will notice the tester light up. This means you made ground and the light should be fix .
COOZE is offline   Reply With Quote
