Closed Thread
Old 02-08-2006, 04:46 PM   #76
boomer
I am interested in your AA system. I have a 1996 328i. I would like to know exactly what else I need for the system to function correctly on my car. How much exactly is the software? I don't want any suprises or piston ring failure. Why exactly did your rings fail anyway? Was it a detonation issue? You can email me at boomincaraudio@yahoo.ca thanks
boomer is offline
Old 02-08-2006, 05:07 PM   #77
JazzM
The reason for failure was a bad installation. The installer who put the kit on ended up boosting my crank case hence the reason for blown rings. Make sure you get it installed correcty.
You will need software for your kit. There are several options that you have with regards to that. Locally you can go through either MarkD (on this board) or even superchips. Otherwise you can send your ECU for programming to AA.
Other than that you won't need anything else. Again, can't stress enough how important it is to get a competent mechanic to install this kit for your if you're not mechanically inclined. Installation instructions are also included on CD. Installation is estimated to take about 12 Hrs.
T.
T.
JazzM is offline
Old 02-08-2006, 07:25 PM   #78
thinair
moderationistismingly
thinair's Avatar
Send a message via ICQ to thinair Send a message via MSN to thinair
So the chip (not the ECU) isn't included with the kit?
thinair is offline
Old 02-08-2006, 07:29 PM   #79
JazzM
I'm throwing in my ECU as well... if the new owner can make use of it that's good. In order for them to use the ECU they will need to work out the issue with EWS (disable it, etc..). The ECU/software is for a 2.8L application.
It'll probably be easier, faster and better to just simply get your own software...
T.
T.
JazzM is offline
Old 02-09-2006, 08:05 AM   #80
kenmar
What exactly do you mean by ".. boosting my crank case"?
kenmar is online now
Old 02-09-2006, 09:17 AM   #81
JazzM
One of the vacuum lines from your intake manifold goes to the crank cast to provide vacuum. The installer didn't block that line off as was specified in the instructions. Hence when the boost hit, it would also presurize the crank case.
T.
T.
JazzM is offline
Old 02-09-2006, 11:22 AM   #82
Furious
BMW again.
Furious's Avatar
im assuming that all the piping and what not was actually for an M3 and just the software was set up for a 328? im only asking because ive contacted AA and said that if the kit was for a 328, that it wont bolt onto my car's engine
.. .basically was this a 328 kit? or an M3 kit to start?
Furious is offline
Old 02-09-2006, 11:45 AM   #83
JazzM
2.8 kit. The 2.8 and M3 kits are the same, only difference is the software.
T.
T.
JazzM is offline
Old 02-09-2006, 01:46 PM   #84
kenmar
T.
My installation CD outlines some minor differences in plumbing which you could probably fabricate out of exhaust tubing. Other than the s/w, the two applications are the same as far as I can see.
Old 02-09-2006, 01:53 PM   #85
kenmar
Sorry, I forgot that the M3 also comes with a larger intercooler. The smaller bumper on the non-M cannot accomodate it.
Old 02-09-2006, 01:59 PM   #86
JazzM
Please not also this is a 2004 kit. The current kits on sold by AA are slightly different (and most likely used the same intercooler whereas presently the M3 has a slightly bigger one).
T.
T.
JazzM is offline
Old 02-09-2006, 02:14 PM   #87
greekthang
greekthang's Avatar
JazzM not to kill your post but people have to be aware that are interested in buying this kit that if they need the software it will run them about $400-$500U.S. so add that onto the price of the supercharger. Needless to say though this supercharger kit sounds like its in great shape and a great deal. Free bump
Its all about rolling in the X5 !!!
greekthang is offline
Old 02-11-2006, 02:50 PM   #88
JazzM
Thanks, yes software is required to get the most from this kit and to properly tune it to your setup. PM's replied
T.
T.
JazzM is offline
Old 02-14-2006, 04:57 PM   #89
JazzM
bump for the week
T.
T.
JazzM is offline
Old 03-08-2006, 10:20 PM   #90
JUICY J CAN'T
propr'one's Avatar
bump this ever get sold?
hid headlights
propr'one is offline
Closed Thread
