Old 10-04-2005, 12:33 PM   #1
digiital
digiital's Avatar
A/C Pressure
Ok so I took a trip to the US last weekend and picked up a A/C recharge kit. Now the thing is that I'm missing the little sticker(I know it was there before) how much I should charge up the A/C system too.
The car is a 96 318i(m44) . Anyone know the pressure?
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover.
Mark Twain
digiital is offline   Reply With Quote
Old 10-04-2005, 07:24 PM   #2
digiital
digiital's Avatar
Interesting. I connected the pressure gauge, and it said that the system was all charged and all fine. The AC is working and cold is coming out, just don't think it's cool enough, maybe it's just the problem with 134a, not as cold as the older Freon(Which my older car had)
Mark Twain
Old 10-04-2005, 08:37 PM   #3
JUICY J CAN'T
propr'one's Avatar
Although i'll admit i know little on the subject, i know there was an issue of converting the older-gas cars to the newer gas, i think something needed to be done other than changing the gas alone. i'd look into it
Old 10-04-2005, 09:29 PM   #4
digiital
digiital's Avatar
I think you must of mis-understood. The 96 I have IS using the newer(134a) gas. I think the problem is that the older stuff(what ever the name was) had a colder temp, compared to the newer stuff. Maybe in the back of my head I was thinking that the bimmer was low on gas and thats why it wasn't as cold as my 92 car.
Mark Twain
Old 10-04-2005, 09:36 PM   #5
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
did u get it in the cans..
cause it will take 2 of them.. which is about 2.2 lbs
UNDER CONSTRUCTION
Old 10-04-2005, 10:11 PM   #6
Justin e36
Justin e36's Avatar
you did change your microfilter, right?... if it can't push enough air out the A/C will choke up and won't get very cold.
And yes, the newer 134a is not as cold as the older A/C systems... but it's friendlier for the environment.
Old 10-04-2005, 11:30 PM   #7
digiital
digiital's Avatar
Ya the kit I got came with a LARGE can, and also got a second one, but since the system was FULL I didn't put anything into it.
Mark Twain
Old 10-04-2005, 11:31 PM   #8
digiital
digiital's Avatar
Good question. I've had the car for 6 months and I haven't changed it, and as far as I know it's never been changed. The car now has 100,300Km and I got it at about 92,000. So maybe I should take a drive to bmw get a filter and go ahead and change it anyways. Just in case.
Mark Twain
Old 10-05-2005, 01:07 AM   #9
Justin e36
Justin e36's Avatar
filters are cheaper at Canadian Tire... same thing, different packaging.
Old 10-05-2005, 01:56 AM   #10
digiital
digiital's Avatar
?? Crappy sells micro filters for bmws? We are talking about the one just above the passengers legs right? Not the engine air filter. If thats the case, I'll just walk across the street then
Mark Twain
Old 10-09-2005, 09:06 AM   #11
Dudesky_E36
Dudesky_E36's Avatar
Send a message via AIM to Dudesky_E36
Stick a thermometer in the center vent. The ones you use for cooking meat in the oven work well. It should be blowing about 45F degrees if you're in doubt about how cold it should be.
Dudesky_E36 is offline   Reply With Quote
