Old 09-28-2005, 12:11 PM   #1
calgaryE30M50
FS: fully built 99 m3 motor
I have a FULLY BUILT OBD1 converted 99 M3 motor for sale.
MOTOR MADE 410rwhp on 7PSI and has way more potential
Features:
- Rebuilt Motor approx 12,000km on motor
- 1999 M3 Motor w/OBD1 Conversion
- Shrick Cams
- Wiseco Stock Bore Forged Pistons (86.4mm)
- Cometic MLS Head Gasket 14mm
- Raceware Head Bolts '
- BMP Aluminum Flywheel
- Spec Stage2 M3 Clutch Kit (15,000km)
- All accessories included
- OBD1 413 DME included ( With OBD1 NA map for 280+ hp )
Web site with a little history and DYNO PLOTS ( Mustang dyno )
http://rage2.com/project01.htm
Pics:
Front of motor:
Exhaust side:
Intake side:
( has plastic cap as housing was swapped from 2.8L motor )
OBD1 wire harness:
I can take more pictures of anything you guys want to see just tell me !!
Asking price is $8000.00 US OBO for everything including accessories !!!!
Michael
1986 325es
93 M50 motor swap
95 M3 cams
RMS stage 1 (v1) supercharger setup for sale
3000 CDN without software
( unless you want RMS chip )
calgaryE30M50 is offline   Reply With Quote
Old 09-28-2005, 01:11 PM   #2
JazzM
That price is a bit high since S52 motors these days go for 2-3500 USD. The price range you're referring to is even above low milage S54 motors with all accessories and wiring which produce 333 hp.
I could see this one seling in the 4.5-5K USD range especially since I don't see performance header (kromerkraft, etc.) or manifold included...
furthermore on a "built" motor you're leaving a plastic thermostat housing???
Good luck with the sale none the less...
T.
T.
Old 09-29-2005, 06:21 PM   #3
SickFinga
SickFinga's Avatar
14mm headgasket???? I hope you mean 1.4mm
What CR you got with that headgasket?
and yet, 8k is a for that engine, unless it comes with SC
