Old 10-21-2013, 11:59 AM   #1381
Originally Posted by _JohnnyD_ View Post
Will a set of 17x8 at 0 offset fit on the front of an E30 with some minor fender work? What kind of tires would you need?
Only with added camber, through plates or otherwise. -3.0 or so. 195/40 or 205/40.
Old 11-22-2013, 01:09 AM   #1382
Diesel88
I want to run Enkei GP5 rims in 17X8, the off set comes in either 30 or 45. Which off set would work best and what size adapters would I need? Not sure if I want to lower the car so what would be the best size tire to clear fenders?
Diesel88 is offline   Reply With Quote
Old 11-22-2013, 12:31 PM   #1383
Both require spacers to fit. I'd suggest the +30 version with 10mm spacers all around. 215/40 or 205/40 tires.
Old 12-23-2013, 09:53 AM   #1384
Jdarwin
Found some RS reps on eBay - 16x8 / 57.1 center bore +20. What would be the recommended tire size without fender mods? Stock suspension 1989 325i but may lower 1" at some point. Thanks in advance for the advice.
Jdarwin is offline   Reply With Quote
Old 12-27-2013, 08:25 PM   #1385
Hartgefan
Hi Mystikal,
Firstly Thank you for all the great info.
I have just purchased some Hartge split rims 8.5Jx17 ET 46 (5x120) and i want to run at least a 225/40/17 on it. I have a E30 325i What do i need to do to correct the offset and make it fit . I am hoping that that the adapter kits can compensate for some ofthe difference in offset. I plan on rolling the fenders as well.
Again Thanks
Kaz
Hartgefan is offline   Reply With Quote
Old 01-03-2014, 11:16 AM   #1386
205/45 or 215/45 will fit without fender rolling.
Old 01-03-2014, 11:17 AM   #1387
Originally Posted by Hartgefan View Post
Hi Mystikal,
Again Thanks
Kaz
225/40/17 doesn't really exist, which makes E30 fitment annoying.
I'd suggest using 25mm adapters and 215/40/17 tires.
Old 01-03-2014, 12:00 PM   #1388
Hartgefan
215's on 8.5j's will it look euro (stretched) and do i still need to roll the fenders?
Again Thanks
Cheers
Kaz
p.s who makes the best/strongest PCD adpaters. (edit)
Old 01-04-2014, 12:13 PM   #1389
Again Thanks
Cheers
Kaz
Yes, you will need to roll the rear fenders. There will be a small stretch, but no inner barrel showing. H&R makes a full line of adapters now, that's your best bet for quality.
Old 01-04-2014, 12:28 PM   #1390
Hartgefan
Thanks mate, i really appreciate the help.
Cheers
Kaz
Old 01-06-2014, 08:50 AM   #1391
Hartgefan
Hi Mystical,
I should have mentioned that i am only dropping the e30 30mm from stock.
Decided to re drill the hubs as the PCD adapters for 4x100 to 5x120 are not made by H&R as they believe them to be unsafe. only one company does them and has swerved that very question on a number of forums/posts.
Will re drilling and using spacers instead of PCD adapters change any of my tyre values or am i still stuck on 215's. What would i have to do to get the 235's on?
Apologies if it sounds like i am asking the same questions, Just hoping that now i am not using pcd adapters which have a min thickness. so i can push the rim in a bit and get the wider tyre 235's would make me a very happy, slight euro look would not (no offense to the euro boys)
Thanks mate.
Kaz
Old 01-06-2014, 02:43 PM   #1392
Hi Mystical,
Thanks mate.
Kaz
I wouldn't redrill the hubs personally. That said you could fit a 235 in the rear with a 15mm spacer. You need the 25mm on the fronts to clear the suspension though.
Old 01-06-2014, 03:09 PM   #1393
Hartgefan
Cool thanks dude.
Dont suppose anyone has any pics of 215's on 8.5jx17 - not had too much luck with google.
Cheers
Old 01-08-2014, 09:28 PM   #1394
solomid
Looking in to getting Rota Alecia for my 1990 325is. 15x8 with a 4x100 bolt pattern but I'm not sure about the offset. Their site offers et -5 to +15.
Car currently has uuc bbk and D-Force 15x7 et +25 rims and 205/50r15 tires.
I'm new to this fitment stuff so sorry if I'm missing any infos.
solomid is offline   Reply With Quote
Old 01-14-2014, 10:17 AM   #1395
Hartgefan
What about 8.5jx17 ET 46 with a 20mm spacer/adapter with a 215/40/15, will that fit without rolling the rear arch.
Thanks again
