Old 07-25-2013, 03:01 AM   #1351
tchung
I am looking into a set of BBS RM wheels from a VW. The size is 15x6.5 and the offset is ET33. I am thinking of fitting them with 205/55R15 or 205/50R15 tires. What spacers (if any) do it need? Thanks.
tchung is offline   Reply With Quote
Old 07-25-2013, 02:53 PM   #1352
No spacers needed with 205/50s but they look pretty terrible without them IMO. Some 205/55s bulge enough to touch the front struts.
BBS RM's were put on this earth for E30 owners to bolt 1-2" larger lips on them.
Old 07-25-2013, 03:21 PM   #1353
tchung
Thanks Jay for your expert opinion.
Old 07-25-2013, 06:12 PM   #1354
Cruisin'
Hey guys im looking at picking up some bbs rs replicas they are 4x100 as they should be but im just worried about offest they are 16x9 offset of +20 and have 3.25 lips. I plan on putting the car on coilovers and dropping it and rolling the fenders will these wheels fit? thanks
Cruisin' is offline   Reply With Quote
Old 08-08-2013, 11:46 AM   #1355
immymechanic
I have '89 325is with bilstein sports and h&r sport springs. Right now I have the 14x6.5" basketweaves with 195/65/14 tires.
I too ^^^ am looking at a set of STR wheels that are offered in 16x9 with et +20
For this option, I have seen what's usually suggested with STOCK SUSPENSION i believe: is running the x9's at all four corners (vs. running a x8 up front) and using 205/45/16 tires all around. Also running a 3mm spacer up front and nothing in the rear.
Is this correct or am I off here? Using a reference (see pic below) i'm thinking I'd need spacers in the front AND the rear to achieve a FLUSH look. I don't want the tire to extend beyond the fenders at all, and I don't want to have to roll the fenders.
Would it be possible to run a wider tire? What's a wider tire you can run on all four corners without rubbing issues up front (for rotation purposes I'd like to keep them all the same). What would be the spacer setup then?
I appreciate the help, it's often tough to utilize like 4 different calculator sites together to try and visualize and figure out what setups will work. Plus some automatically upsize the tire to a 235 when you tell it that you wanna run a 9" wide wheel, so that doesn't help much.
Thanks!
For reference, this is the flush fitment i'm looking for. Not my car, but props to whomever owns it! He's running a 16x9" ET10 with 225/40/16 tires and using a 15mm spacer to get flush. So would running a et20 wheel require a 25mm spacer to get flush out back?
immymechanic is offline   Reply With Quote
Old 08-12-2013, 04:25 PM   #1356
With 8mm front spacers, yes.
Old 08-12-2013, 04:29 PM   #1357
Thanks!
Keep the final offset close to +10 on a 16x9. 215/40s are the maximum most try to run although 205/45 allows for a better overall diameter and oil pan clearance.
You will have to roll your fenders. You want to run 9" wide flush wheels on a car designed for 7" wheels maximum, you will have to do some work.
There's no way the car pictured is 16x9 -5 225/40.
Old 08-15-2013, 03:43 PM   #1358
Slowered318
Alzor Wheels
What's your thoughts on the Alzor style 010 wheels from ECS Tuning? Looks like they are cast and most likely require spacers.
Ach-ya or nish-nish?
Old 08-16-2013, 11:16 AM   #1359
Another rebranding of cheap Chinese replicas.
They also got the offsets hilariously wrong. I think they intended to make the 16x9s +30 and the 16x8s +12 (which would have looked great on an E30 and fit more cars in general) but got the numbers backwards.
Everyone has a wheel line today.
Old 08-16-2013, 11:30 AM   #1360
Slowered318
Damn... I knew it was too good to be true. China factory don't care about e30, they just wanna make money right!
Oh well, you just saved me $2,500
Old 08-17-2013, 04:36 PM   #1361
E30Jack
offset wrong? sounds like craigslist wheel dealers LOL
E30Jack is offline   Reply With Quote
Old 09-04-2013, 08:10 PM   #1362
I've got some Borbets coming that are 16x9 et15 for me E30.
I figured out that I'll need to run a 5mm spacer in the front to clear. (you mentioned that above)
As for tires, I'm looking at 205/50/16 or 225/45/16 or 225/50/16. These all seem to have people claiming that they fit them on their E30s, but could you cut through the info and recommend one?
I am lowered on H&R Sport springs.
EDIT: I'm thinking I should go with a 205/50/16 in the front and a 225/50/16 in the rear?
Old 09-04-2013, 11:30 PM   #1363
oldskoole30
oldskoole30's Avatar
I believe 215/40/16 would be an "appropriate" size for this setup. If you aren't lowered far enough you can probably go with 225s. 50 profile would be too fat
oldskoole30 is online now   Reply With Quote
Old 09-06-2013, 01:43 PM   #1364
None of those fit. 205/45 or 215/40.
Old 09-18-2013, 01:33 AM   #1365
GetbuQ
I just bought a set of 17x9 +20. What will i have to do to make them fit? Also just bought a full set of coilovers to install with them. Thanks
GetbuQ is offline   Reply With Quote
