Old 02-22-2012, 12:58 PM   #1126
Originally Posted by flex 54 View Post
What wheel spacer's will work on a 89 525 i to mount 3 series M3 rim's on the 5 series car?? I have new longer bolt's, and tried generic speed shop spacer's. Just want the right hub centric one. ????
Thank's Flex 54
Need to know the width, offset, and tire size of the wheels in question.
Old 02-22-2012, 12:59 PM   #1127
Originally Posted by peakn7 View Post
Hi, about to fit 17x8.25 and 17x9.75 both 25 offset, do I need spacers and can I run 245/40 and 255/40 for a race car with m3 flares? Cheers
Yes, that setup should fit fine with flares. Depending on which front struts you use you might need a 3-5mm spacer to clear.
Old 02-23-2012, 10:18 AM   #1128
peakn7
thanks, i'll let you know how i go
peakn7 is offline   Reply With Quote
Old 02-24-2012, 01:45 AM   #1129
panose30
Hi,i have a big problem to solve,1st my car is a 1986 e30 325i,i have Brembo 4 piston brakes front from EVO 9 with 325mm discs and i use 10 mm hubcentric spacers to clear the Alpinas reps which are 17*7.5 et20, 4*100.My main problem now is that i want to change wheels. I want the Dare DR-RS but i dont know what offset to get them to clear the brakes ,the size i want to get is 17x7.5 front and 17x8.5 rear ,i have 215/40 tyres,im gonna need to roll the front or rear fenders??what is the proper offset to get them ?
my car is lowered with sachs absorbers and vogltland 45mm front and apexi 45 mm yellow springs rear
Thank you (sorry for my english,im from Cyprus)
panose30 is offline   Reply With Quote
Old 02-24-2012, 01:38 PM   #1130
Cyprus, awesome. Well unfortunately I can't answer your question decisively as wheel width and offset alone do not tell you what brake clearance will be. Either the brake manufacturer, the wheel manufacturer, or both will have to provide templates (usually sent in the form of .pdf files) so you can test to see if it will work.
Old 02-24-2012, 01:59 PM   #1131
panose30
thank you very much !!i will search more then
Old 02-29-2012, 04:00 PM   #1132
liquidc3lls
Staggered?
Hi there boss, i got a quick one for ya, thinking about grabbing a set of 4 enkei92's staggered, (2 front are 15x7 ET+38) (2 rear are 15x8 ET+25), would these be a simple matter of bolting them on and driving off, or would i require spacers?
thanks for your help
Cheers
liquidc3lls is offline   Reply With Quote
Old 03-01-2012, 12:48 PM   #1133
Cheers
You'll want 15-20mm front spacers while the rears are fine as-is. I'd go 20mm for them to be relatively even with the rear stance.
Old 03-02-2012, 01:26 AM   #1134
liquidc3lls
Thanks sir will do
Old 03-08-2012, 03:01 PM   #1135
Bimmer Guru
I'm about to buy some BBS RS's and am a little worried about fitment. The specs are 16x8.5 with et18 in front and 16x9 with et12.5 in the rear. My car is lowered on the turner motorsport suspension setup and its already a tight fit with 15x7et25 dforces. Will i need a spacer in the front?
Bimmer Guru is offline   Reply With Quote
Old 03-09-2012, 02:10 PM   #1136
You should have a few mm clearance to the front struts. If you use tires that have an unusually large curb protector you may need a 3mm spacer to avoid polishing the strut housing.
Old 03-09-2012, 10:43 PM   #1137
Bimmer Guru
Thanks for the reply! Here is the link to the wheels:
http://www.stanceworks.com/forums/sh...ad.php?t=27282
He offered to make the lip on the inside of the fronts smaller and im thinking about it. but they look really good as is. What do you think?
Old 03-09-2012, 11:25 PM   #1138
Dixie14
what should people keep their offset around when buying rims?
Dixie14 is offline   Reply With Quote
Old 03-12-2012, 12:17 PM   #1139
If he had the perfect 0.5" smaller barrel sitting around, sure. But otherwise leave them as-is IMO.
Old 03-12-2012, 12:18 PM   #1140
There's no simple answer for that. Depends on width, diameter, tire size, car year, model, suspension, etc etc.
