Old 01-03-2012, 01:45 PM   #1081
15x7 +29 is fine with a 205/55 tire.
i/iS/e/eS - share geometry
iX - unique
M3 - unique
Old 01-05-2012, 08:37 PM   #1082
dmracingz
Tuyot
Hello there guys, needing some help here on choosing the correct size of barrel for my BBS RS 17", right now i have 7" wide barrel but it is hitting the front struts and the rear as well, what is the perfect size of barrel for my BBS RS on my e30 325i? should i use 6" or 5.5"? I know i can put spacers to clear that out but i don't want any spacers so i can put wider lips, thanks....
dmracingz is offline   Reply With Quote
Old 01-06-2012, 01:34 PM   #1083
I need the offsets, as well as the hub setup of the car (4-lug? 5-lug?).
Old 01-06-2012, 02:24 PM   #1084
dmracingz
Tuyot
It's 4 lugs. 17x8 et40 17x9 et 43. Its been redrilled to 4x100. The front wheel the back of the face is not flat. The rears the back of the face is flat. Thanks.
Old 01-06-2012, 03:44 PM   #1085
Take away a half inch from the front barrels and a full inch from the rears. This will (just barely) give you the strut clearance you need.
Old 01-07-2012, 02:43 PM   #1086
chanceton14
Im running esm 002s 16x7.5 et20 and Im not happy with how far they stick out(want pass fender but not fender rolling)....What size of spacers do I need to run? Thanks
chanceton14 is offline   Reply With Quote
Old 01-08-2012, 02:48 AM   #1087
3rotore30
Mystikal,
Looking at buying a set of 15" Work Meister wheels as they seem to be quite a nice style and they come in the 4 x 100 pattern.
I run standard suspension but will look at getting some BC coil overs a bit later on. Fronts will have a big brake kit with a 280mm rotor and 4 piston calipers.
I would like to run something with an agressive offset, the lower the better just for looks more than anything else. Not too fussy with width at the front but back is important (as wide as possible).
Would you know the limits of offset and width I can run with a 15" rim?
3rotore30 is offline   Reply With Quote
Old 01-10-2012, 05:08 PM   #1088
dmracingz
Tuyot
Thanks Jay, just got new information about my wheels, the original size of the fronts is .5" lips and 7" barrel, the rear is .5" lips and 8" barrel. We try to fit 6" barrel in the front and rear, the front clearance in the strut is about 8 or 10mm and we put 1.5" lips, and the rear has a lot of room and we try to put some 2.5" lips but it seems its poking a bit, i just have some concerns that i would like to ask you, if i will run GC coilovers later on, if i will run 2" lips on the fronts and 3" lips on the rear, do you think it will poke that much even i rolled and pulled my fenders. thanks.
Old 01-17-2012, 01:12 PM   #1089
You won't be able to space those much if at all without rolling the fenders. Making 7.5" wheels flush is difficult.
Old 01-17-2012, 01:18 PM   #1090
Originally Posted by 3rotore30 View Post
Mystikal,
I have less data on 15" non-track setups than 16" and larger, but I think I can still get it close. This is a very aggressive setup, and would look amazing IMO. You'll need to roll and maybe slightly pull the rear fenders for this depending on height and spring rates (go 12-14K R for best results).
F 15x8.5 +15 (R-Disk) 195/50 or 205/50
R 15x9.5 +15 (O-Disk) 215/45 or 225/45
Old 01-17-2012, 01:44 PM   #1091
Okay, are the original offsets still +40/43? I'll assume yes for the following. All offsets have a 1-2mm margin of error due to rounding (I'm doing this in my head, cut some slack!).
Fronts:
6" barrel 1.5" lip = 17x7.5 +15
6" barrel 2.0" lip = 17x8.0 +7
Rears:
8" barrel 2.5" lip = 17x10.5 +18 (possible but extremely aggressive)
8" barrel 3.0" lip = 17x11.0 +12 (starting to get outlandish)
The other problem with going past 10" is available tires. 225/35 will just stretch onto a 10" and with skill will just fit onto the 10.5". Going any wider requires stepping up to a 245/35 which will make fitment much more difficult.
Old 01-19-2012, 03:54 AM   #1092
3rotore30
Thanks for that, some of the oz=racing Leggenda wheels look nice too but they are the wrong offset for the e30 and only available in pretty limited sizes too.
I also quite like the look of their new CR 01 range too, very nice and a few more options available for colours.
Decisions....
Old 01-21-2012, 09:19 AM   #1093
E30isKing
Need advice, dreaming out loud
Hi there,
First of all thanks for this amazing thread and your support.
These are the wheels in question. I just found them and they are gorgeous.
I have an S38 engine as well so the extra rubber would help.
http://povoadelanhoso.olx.pt/jantes-...-iid-190240504
These are 15x8j ET 10 Front
15x11j ET 35 Rear
Of course I would roll the fenders, if that helps
Thanks,
Paulo
E30isKing is offline   Reply With Quote
Old 01-23-2012, 01:11 PM   #1094
Originally Posted by E30isKing View Post
Hi there,
15x11j ET 35 Rear
Thanks,
Paulo
Not going to fit 11's under an E30, sorry. With fender flares and around +0 final offset (maybe even lower actually), maybe.
Old 01-23-2012, 02:49 PM   #1095
E30isKing
Thanks, I was just dreaming out loud.
However they would look ace on an E30.
In your opinion, among all the possible sizes and shapes, whats the grippiest size tyre the E30 can take, assuming fender rolling isn't an issue?
