Old 03-08-2011, 03:37 AM   #976
Ant_e30
Not trying to be argumentative here (damn, first post, dont want to get on the wrong foot!) but i am a little confused in regard to why you so strongly say 16x8 +/-0 wheels are entirely inappropriate on E30s, and yet you will say to people that 16x9 +15 with 3-5mm spacer is okay. Using the Wheel Offset Calculator, the difference between 16x8 +/-0 and 16x9 +10 (effective w 5mm spacer) is actually +3mm further out for the 9" rim. But you do not tell people it won't fit?
I ask this because i've just bought myself an E30 and really want so aggressive wheel fitment. That said, I dislike the look where the front wheel is poking more than the rear. ideally i want maybe a 5mm-ish of rim poke on stretched tyres. I am looking at running coilovers all round (GC or KW probably) and have been eyeing off the likes of Kerscher Carmonas. I really do not want to run a 3-5mm Slip On, and i feel anything thicker will push the rim out too far. As such i am (sadly..lol) considering the 7.5 +20 up front with a 20-25mm spacer and then the 9" +15 up back. Sound reasonable?
Also when you say fitment up front, what type of camber are you allowing for? I assume aftermarket camber tops and maybe 2-3 degrees?
cheers!
Ant_e30 is offline   Reply With Quote
Old 03-08-2011, 01:43 PM   #977
cheers!
You have to consider where the center of the rim sits in relation to the fender. Let's make things equal. A 16x8 +0 wheel and a 16x9 +13 (just for argument's sake). The 16x9 setup will visually and physically fit better. Why? The tire is still centered at the +13 point. That fact will pull the tire more into the wheel well than a similarly stretched tire on the 16x8. It's not necessarily about where the wheel ends, but how the geometry delta affects the shape of the tire.
Your staggered setup sounds like a good choice. All of my fitment recommendations assume stock upper mounts unless the question mentioned adjustable mounts or I do in my reply.
Old 03-09-2011, 09:08 AM   #978
Ant_e30
Ah fair enough, that makes some sense. i generally think that width and offset can be interchanged, so to speak, but extra width is better simply for further stretch. but i guess the dynamics of it isn't something i entirely considered before. thanks for the input on that!
Old 03-15-2011, 04:04 AM   #979
Ant_e30
my hunt continues..i've found some very good condition 4x114.3 BBS RS 16x7 with 5" backspace (i calculate that to be around +25 offset?) locally and am considering buying them, having them redrilled and getting some new outer lips (look to have 1" lips currently). They're sitting around $410AU (about $400US) for the set but i would be able to go up to $500AU for them i guess.
the only issue is from the research i've done i'd look to widen them by adding larger outer lips, and my options seem to be to add 1.5" (for a 2.5" lip) which will yield 8.5" captive width with an offset of +6, or add 2" (for a 3" lip) which will yield 9" captive width with an offset of +/- 0.
I will have adjustable camber tops but I don't think the 9" +/- 0 will work up front so 8.5 +6 should be okay. But then the 9" +/- 0 up back will still be a squeeze and then may look out of proportion to the front. Really i do not want to run slip on spacers at all, only bolt-ons if anything...
Anyone have any thoughts? Jay? :]
Old 03-16-2011, 03:55 PM   #980
+25 is correct, as are your widened offsets. I like the 8.5" front 9" rear idea, should work well (they will look almost dead-even front-rear). 205/45/16s are a good idea. No spacers needed.
Old 03-25-2011, 09:37 PM   #981
Chris916
Chris916's Avatar
Hey,
Been searching around for the answer to this but just cant seem to find it.
What size spacer will i need to fit 245/50-16 on 16x9 et15. I understand i may have to do some fender modifications but it shouldn't be a problem.
Track - 1991 318is - My Track Car Build
Street - 1987 340i - E30 M60 Build
Chris916 is offline   Reply With Quote
Old 03-28-2011, 12:11 PM   #982
Originally Posted by Chris916 View Post
Hey,
Fender modification is an understatement.
10mm should be enough to clear the struts in front. Shouldn't need anything in the back.
Old 03-28-2011, 11:08 PM   #983
Chris916
Chris916's Avatar
^Awesome! thanks. will most likely run 10mm all around then to keep it even. fenders will be cut up and flared
Old 04-04-2011, 03:25 AM   #984
voluted
voluted's Avatar
Currently have a set of wheels on the car with the following stats:
17x7. et40 with 215-40's.
I was wondering what spacers I should be using to get the tire as flush as possible without having to do any fender modification. I am currently lowered about 1.6" in the front and 1.4" in the rear. I was thinking 20mm all around or 15mm front and 20mm rear.
Old 04-04-2011, 12:43 PM   #985
^ Perfect setup, 15/20.
Old 04-06-2011, 02:36 PM   #986
voluted
voluted's Avatar
Thumbs up
Just put the stud kit and spacers on today and the wheel fit is spot on. It may just be my imagination, but the car seems to understeer a lot less now (yay). No rubbing either. Thanks for the input Jay!
Old 04-06-2011, 04:01 PM   #987
That was quick. Congrats, glad I could help you out.
Old 04-08-2011, 03:20 PM   #988
voluted
voluted's Avatar
I ordered the spacers from NovusTech in Cambridge (via eBay) when I saw your post. Their delivery was really fast! I already had a set of 80mm studs with the nuts sitting at home.
Old 04-12-2011, 05:36 PM   #989
scincarov
new here help help
Hi I'm looking to get some of those xxr eBay rims but they r 16"x8 with 0 offset will they fit and what type of tires will I need pleas help
E30 1987 325I
scincarov is offline   Reply With Quote
Old 04-12-2011, 05:37 PM   #990
scincarov
help
HElp HELP
