Old 10-19-2010, 05:31 AM   #931
LeeChristmas
"You Could of Killed Me"
LeeChristmas's Avatar
im likes the looks of this
found this pic on the net of this track car running the trm's looks good - you think those are 225/50r15's ?
[IMG]www.ddurrelltech.com/bmw/trackwheels.jpg[/IMG]
LeeChristmas is offline   Reply With Quote
Old 10-19-2010, 11:25 AM   #932
Those are Kosei K1s wrapped in 225/50/15 R-comps.
Old 10-30-2010, 01:08 PM   #933
VasFinest
Hey just joined this forum, it looks awesome. I have an '86 e30 325. I found some Privat remember rims. They are 16x7, Will these fit on my car? Also what offset should I get, and what size tires? Thanks in advance! EDIT: the two offset possibilites are 20 and 35. which should i be looking at?
VasFinest is offline   Reply With Quote
Old 11-01-2010, 12:15 PM   #934
20 offset. 205/50, 215/45, 225/45 will all work without rubbing.
Old 11-02-2010, 11:19 AM   #935
LeeChristmas
hey jay more answers please
motegi racing mr 12's - 15x7 - 4x100 - what was the offset on those - cant find any info or spec's on wheels - i know the wheel is nla - possible idea for my ride - was wondering how thick of a spacer im going to have to run to put these on my 89' e30 - friend has a set on his ITS e30 racer and is willing to part with them so any help is greatly appreciated - thanks again jay - you da man
Old 11-02-2010, 01:47 PM   #936
No idea, maybe ask him what size he uses.
Old 11-21-2010, 03:31 PM   #937
Dissembler
Dissembler's Avatar
Rims are 16x7.5 ET18, 225/50/16 on the front and 245/45/16 on the rear be even close to fitting? Fender rolling is expected.
S52 E30
Old 11-22-2010, 12:10 PM   #938
Not a chance. Even 225/45 will be tough in the rear.
Old 11-22-2010, 02:12 PM   #939
Dissembler
Dissembler's Avatar
Didn't think the rims would fit with such a low offset. I have them laying around and it would've been very convenient if I could have used them (would've required a fill'n'drill though). Oh well.
In a 16x7.5, 16x8 what offset would I be looking for? I know 225s fit at all 4 corners no problems, but I really want to run a 245 in the back (due to future power goals). Car is an early model so it does have the higher rear arches.
S52 E30
Old 12-13-2010, 12:40 AM   #940
jmancan1993
Exclamation
I am new to this forum but just joined to get some questions answered and this thread should definitely be the place to do it. I have stock 14" basketweaves and a set of 205/70/14 winterforces sittin in the garage. I am sittin on stock ride height and was wondering if I am going to rub at all if I mount these? I'd really appreciate the help.
jmancan1993 is offline   Reply With Quote
Old 12-14-2010, 02:46 PM   #941
Yes, you will rub with that size.
Old 12-21-2010, 11:20 AM   #942
micvin
New to these forums, but found it searching for lowest offsets that can be done on my 1991 325iC.
I want to know if anyone has put on something similar to...
17x9/17x10 wheels with an offset of 23 without spacer adapters and et8 with 15mm spacer adapters. I know it is extreme, but is it possible with a good amount of stretched tire, a bit of fender roll and pulling? Maybe not? I have no idea since this is my first BMW.
Thanks,
Mike
micvin is offline   Reply With Quote
Old 12-21-2010, 11:36 AM   #943
Thanks,
Mike
Not possible. I'm all for extreme setups but that's too far to pull off without creating new rear arches (it's beyond what a slight pull can do). I'm assuming the 15mm adapters are required? If the wheels are actually 4x100 then by all means mount them with 10mm front spacers to clear the struts and use the rears with no spacers; if those are of a different PCD, then you're out of luck.
Old 12-21-2010, 12:00 PM   #944
micvin
Yes, the wheels are currenty redrilled to 5x100 with et23 requiring adapters to fit 4x100.
Is there anywhere on the net to see actual pictures of different set-ups? I need to get an idea of what I really want. i also here the later model e30s have lower arches and the cabbys have lower offsets. Is this true?
One more question...what is a good combo offset/width/size setup that looks tough, but not too extreme?
Thanks for the speedy reply.
Mike
Old 12-21-2010, 05:43 PM   #945
rimtuck.com has some stuff, also check out dedicated E30 forums like R3Vlimited and E30Tech.
Common setup is 16x9 +10 front +5 rear, 215/40s.
