Old 05-22-2010, 02:01 PM   #856
TobyBe
Either custom adapters or machining of the hub bore plus regular spacers. The Mini wheels have a 56.1mm bore, which is 1mm smaller than the E30. Spacer size, 25-30mm (yes, huge).
Figure $200-400 in hardware just to get the wheels on.
I program CNC machines for a living so this is something that I should be able to make. Does anyone have the specs on spacers? Like the diameter of the lug holes and overall diameter of the spacer?
TobyBe is offline   Reply With Quote
Old 05-22-2010, 02:18 PM   #857
I don't, but try searching on R3VLimited. I swear I've seen autocad or whatever drawings on there.
Old 05-22-2010, 02:20 PM   #858
TobyBe
thanks for all your help!!!
Old 05-22-2010, 08:33 PM   #859
TobyBe
Jay, I have to thank you one more time for all of your help. I have learned so much about rims the last day and a half. If not for the help of you/all of these BMW forums I would've picked up the rims and been really pissed when they didn't fit.... Your help was/is very much appreciated. Thank you. I'll post some pics of the car when I am finished. Now to find a forum on body kits....
Old 06-04-2010, 02:39 AM   #860
fz-e30
fz-e30's Avatar
is redrilling a 5X120 to a 4X100 a good or bad idea?
fz-e30 is offline   Reply With Quote
Old 06-05-2010, 11:52 AM   #861
There are proponents on both sides. If it's filled and redrilled properly, it will hold up, even to track duty. The trick is that word...properly.
Old 06-11-2010, 12:31 AM   #862
Yamahammer
Warlock of the century
Yamahammer's Avatar
I am going to be running 16x9 all around with et5 up front and et 0 in rear, i know i am going to have to roll my fenders, nut what tires size should i use, 205/45/16 or 205/40/16?
Old 06-11-2010, 12:33 AM   #863
Yamahammer
Yamahammer's Avatar
to add to that /\ i have the wheels and they are 15 et but i have not bought spacers yet, so should i run 5 et front and 0et rear or should i do 10 front and 5 rear? or something in those ranges?
Old 06-11-2010, 07:24 PM   #864
205/45. 205/40 looks...bad.
You can go with either 5/10 or 10/15, just depends on how much rolling/pulling you're okay with.
Old 06-11-2010, 08:40 PM   #865
SamE30e
SamE30e's Avatar
I have a couple on my laptop I did while I got bored. Any person with solidworks or solidedge or catia should be able to make a wheel spacer in about 30 seconds, given they have the information. Tell me what you want and if I have time I'll throw one together.
85 325 - Turbo M52B28.
Old 06-12-2010, 10:46 AM   #866
Yamahammer
Yamahammer's Avatar
Ya thats what i thought, we will see how it goes.
Old 06-24-2010, 01:37 AM   #867
Cal_MX5
Hi I'm new. Just wondering about XXR 501's in 16"x8" ET15 with 225/45/16's on a 1990 318is. I am prepared to have the guards rolled, but not pulled. The car will have BC Racing coilovers on it. Will these fit? Otherwise I'll probably go for 15" Ronal LS's with 225/50/15's.
Cal_MX5 is offline   Reply With Quote
Old 06-24-2010, 06:36 PM   #868
Will very likely need pulling.
Old 06-24-2010, 07:54 PM   #869
Cal_MX5
Thanks. Ronals it is then.
In terms of tyres that fit no problem, you quote a Falken ZE-512 on page 2 which has been superseded by a ZE-912 with a section width of 231mm, which is 9.094 inches. Sounds like they will fit? There isn't much else available in that size.
Old 06-25-2010, 07:40 PM   #870
They will fit. With the Ronals you can fit a 9.4" section width without fender rolling. That wheel started my obsession with fitment about 10 years ago.
BTW that stated width is on a 7" rim, it's more like 9.2x" on the Ronal.
