Old 11-11-2009, 06:54 PM   #766
I know more than a few Aussies have shipped down the new 17x8 ET25 ARC-8 BBS replicas. 235/40/17s with barely a fender roll.
Old 11-11-2009, 07:02 PM   #767
S54E30
Where can I get those?
S54E30 is offline   Reply With Quote
Old 11-11-2009, 07:04 PM   #768
http://www.apexraceparts.com/3-Series-BMW-E30_c_31.html
Old 11-11-2009, 07:22 PM   #769
S54E30
Thanks for the info and link. I will check out those wheels. I am still considering the zero offset wheels though for the widest track and look. 16" ESM rims with 205/60/16 tyre.
Old 12-08-2009, 10:15 AM   #770
theox69
theox69's Avatar
You'll be rubbing.
I know you meant 205/50, but you'll still be rubbing.
With zero offset wheels, you really have to choose tires wisely because they'll more than likely be in contact with your fenders. Not to mention you'll also need some rolling.
theox69 is offline   Reply With Quote
Old 12-08-2009, 11:05 PM   #771
S54E30
I will be using 205/50/16 for that rim and I will post pics when it's done next week. The brake calipers need to to be shaved a little to clear the inside of the rim, because the rim tapers slightly. It should be a good fit though.
Old 12-09-2009, 05:19 PM   #772
e30_kid89
The Afro-stig
e30_kid89's Avatar
Hay Jay, If I were to run the 8.5" Ds2's all around, what tire size should i be looking at? I also plan on rolling the fenders all around too so i can fit decent sized rubber.
Old 12-10-2009, 02:58 PM   #773
235/40 works. 245/35 is perfect but expensive as hell.
Old 12-30-2009, 05:00 PM   #774
JdmEuroNorth
JdmEuroNorth's Avatar
I'm planning on getting Diamond racing steel rims, as you more then likely know they make about any size/offset/etc you want.
What would be the best offset and width for an e30 to prevent rubbing and what tire size won't rub? (I was thinking 15X7 or 15X8 for rim size)
JdmEuroNorth is offline   Reply With Quote
Old 01-02-2010, 11:04 AM   #775
What type of fitment are you looking for though? Like "stance" or to fit the largest tires possible?
Old 01-02-2010, 06:01 PM   #776
Nomadic
Send a message via Yahoo to Nomadic
wheels and lowering
Hello all, new to this forum, saw this thread in a search and found that you peeps are very knowledgeable. So here goes my question, i have 15x8 wheels 0 offset with 4x100 pattern and a 3inch lip. I received a set of H&R sports, 1.4 inch front and .75 rear, will i need to do roll the fenders for the wheels to fit, also using tokico hp "blues". The tires i am using are 195/50/15. They fit ok now, and have fender space, but worried about the drop. I do not have the tokicos or H&R's on yet, have old leaky saggy suspension at the moment and rides awful atm. Also replacing the ball joints, control arms, bushings, tie rods, sway bar links, strut mounts and shock mounts.
Nomadic is offline   Reply With Quote
Old 01-02-2010, 06:31 PM   #777
JdmEuroNorth
In the rear I'm looking for the widest tire possible without ANY rubbing.
Fronts I don't want the widest tires I can find but I want a decent amount of rubber contact.
I believe heavily with the saying function over form.
Old 01-07-2010, 06:18 PM   #778
I don't usually recommend that fitment, because the wheels (especially the fronts) end up so far outside of the arches.
You'll just have to roll the rear fender lips.
Old 01-07-2010, 06:19 PM   #779
Without rolling, 15x7 +25 with 225/50 or 225/45 would be nice.
With rolling, 15x8 +20 with the same tires.
Old 01-08-2010, 02:24 AM   #780
Nomadic
Thank you for the advice, i may hold off on the lowering for a bit, wait till i get a different set of wheels, though i may just try it to see how bad the fitment is. If awful then off with those wheels. And thanks again.
