05-08-2009, 09:40 PM
#691
Car: 90/325i 05 WK
esm 012
Hello...i was wondering if i need to do any modifications w/17x7.5 offset 20...also what size of tire should i use??? i have a 1.25" drop if that matters...Thanks in advance.
Whomever Said Money Can't Buy Happinnes, He Dind't Know Where To Go Shopping
05-09-2009, 11:35 AM
#692
Car: S54
No modification, 215/40/17 tires.
05-19-2009, 02:23 PM
#693
Car: '89 325is
Hey, just wondering if these wheels would fit my '89 325is: Ronal R8, 15x7 ET25 without any modifications? I have a H&R springs, Bilstein Strut suspension setup. Also, what tires should I used? Thanks in advance!
-Sam.
05-21-2009, 06:12 PM
#694
Car: S54
-Sam.
205/55/15 or 225/50/15 will fit without modification. And those R8s should need nothing other than the stock bolts to get them on.
05-21-2009, 07:00 PM
#695
Car: E30 325iS M-Technik
Hey Jay, I have a set of 17x8 ATS DTC wheels, the offest is ET20.
I ordered some Bridgestone RE11's in 205/45/17, but is there a more appropriate size? I'm scared there isn't enough meat on them...I've heard the RE11's are usually wider than normal though...
05-21-2009, 08:00 PM
#696
Car: S54
That size is fine, especially with how good those tires are. There will be a slight stretch on the sidewall probably, but nothing to worry about.
05-27-2009, 04:47 PM
#697
Car: '87 325is
Hey Jay, i was wondering if I could fit motegi sx5 16X7 with a 35mm offset, and if so what size tire and spacers would i need?
06-01-2009, 04:48 PM
#698
Car: S54
15mm spacers all around, 205/50, 215/45, and 225/45 tires will all work.
06-06-2009, 12:30 AM
#699
all by chance...
Car: 91 318i
all great and wise Jay,
205/55/r15 et35 with 8mm front spacer and either 8mm rear or 15mm rear spacer with 60/40 springs... will they rub without rolling? thanks in advance
06-06-2009, 02:02 PM
#700
Car: 87 325is OBD I S52
what is the max width of a 16" wheel i can run with a 2.4" drop?
1987 325is(Midnight Tuning Tuned OBD I S52  ) - Current Summer Car
2012 Hyundai Veloster Tech- Daily Driver
06-06-2009, 02:03 PM
#701
Car: 90 sr20det 325is
You could run a 10 with the right offsets and tire size's, its been done. I'm not sure about wider though.
06-08-2009, 01:03 PM
#702
Car: S54
You could run 15mm all around with room to spare. So, yes.
#703
Car: S54
With just a fender roll, 9" all around.
06-08-2009, 03:44 PM
#704
all by chance...
Car: 91 318i
06-09-2009, 12:35 AM
#705
Almost Sideways
Car: 1990 325i
210/50/16 et20 on 8inch wide rims. will they fit? can i make them fit?
-i also have apex springs with bilstiens...its about a 2inch drop
jake
