Old 07-22-2007, 10:01 PM   #496
86coupe30
1990 325is
86coupe30's Avatar
Send a message via MSN to 86coupe30
what are the condition on the 16s..
86coupe30 is offline   Reply With Quote
Old 07-22-2007, 10:07 PM   #497
ZiMMie
Mint.
there rear are lke brand new.
the front has about 60% thrend left.
#E36-S54 #CSLWannabe
Old 07-22-2007, 10:09 PM   #498
86coupe30
1990 325is
86coupe30's Avatar
alright.. aug 3 ill come get them... im pretty busy untill then
Old 07-22-2007, 10:09 PM   #499
ZiMMie
yea sure if they available by then, it will be urs.
Old 07-25-2007, 12:00 PM   #500
86coupe30
1990 325is
86coupe30's Avatar
has anyone ever done a stud swapon their rotors before..
i mean like converting instead of using wheel bolts make it have permenent studs coming out.. i think im gunna do that soon. save the hassle of stupid bolts going in the wheel..
Old 07-25-2007, 02:04 PM   #501
Gleb
E30 ..?
Gleb's Avatar
Just did it on my E30, very easy to swap wheels at the track... for the street it's probably a waste of money.
Old 07-25-2007, 02:06 PM   #502
86coupe30
1990 325is
86coupe30's Avatar
i was gunna do it myself it doenst cost every much for wheelstuds like 50 bucks probably do that tomorrow
i just am sick of putting wheels on with the bolts. itsa pain in the asscompared to with permanent studs
and its stronger.
Old 07-31-2007, 10:23 AM   #503
Level8Drumme
Ok, I've got an E30 with the spec-e30 suspension, and 15x7 track wheels 25mm offset. Can I fit 225/50R15 nitto NT-01's on the car? Or will I have to go with 225/45R15's?
I just put some Sumitomo HTR200's 205/60R14 on the stock 14x6 wheels. They work just great on the street
Level8Drummer
Level8Drumme is offline   Reply With Quote
Old 07-31-2007, 11:22 AM   #504
I've done it, they don't bolt to the rotor's they go directly into the hub.
Remember to use the strongest lock-tite you can find.
Old 07-31-2007, 11:47 AM   #505
Level8Drummer
The 225/50's will be fine, although the 225/45's might be faster around some tracks (shorter gearing). The 50 is the correct rolling diameter though. Nice tire choice BTW, those Nitto's are getting rave reviews.
Old 07-31-2007, 11:55 AM   #506
Level8Drumme
Thanks, we'll see how everything turns out. I've already got a 4.10 in the rear, so I don't want to shorten the gearing too much more...
I can't decide between the toyo ra1's and the nitto's...but that's not for this thread
Thanks man!
Level8Drummer
Old 09-15-2007, 10:19 PM   #507
325man
e30 adict
I have a set of rotas 205-50-16, et 40, just a 20mm hubcentric spacer will work? even once i lower the ride height?
Another thing is the centre bore of the wheels is too big, is there spacers for the centerbore aswell? i dont want to put the wheels on if theyre not a good fitment on the hub.
Thanks, Vic.
325man is offline   Reply With Quote
Old 09-16-2007, 04:12 PM   #508
Thanks, Vic.
15mm hubcentric spacers would be a better choice, as you'd have the option to 225 tires without rolling the fenders.
90% of the wheels you see on E30s have oversized centerbores. You just need hubcentric rings, good wheel/tire shops should have a stock of them.
Old 09-16-2007, 09:42 PM   #509
325man
e30 adict
Thanks, i guess 15mm it will be, they might cost less so that ok for me.
Old 09-17-2007, 10:05 PM   #510
mantonia
Someone is advertising some 17in rims for an E30, but I'm not sure if they'll fit my car ('91 E30 318is).
http://www.maxbimmer.com/forums/showthread.php?t=95200
If you check
http://www.bigwheels.net/?location=w...30,%204%20lugs)
the details are: 17x7.5, 4x100, offset: 45.
Is there any way that a 45 offset could fit a stock E30 without having to do some major bodywork?
mantonia is offline   Reply With Quote
