Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 05-02-2007, 08:18 PM   #421
Shurian
SpezE30
Shurian's Avatar
Mistykal i got my rear wheels with et25 today,my question is to go 215/40/16 all around or 205/45/16 front and 215/40/16 rear?also is it can be the prolbem to stretch 215 on the 9 inch wide rim?tnkx.
87 325e DD
89 325ic Project
Shurian is offline   Reply With Quote
Old 05-02-2007, 09:26 PM   #422
kapt_krickee
kapt_krickeet
kapt_krickee's Avatar
yah...wheels will forever be a mystery to me..offsets and measurements don't work in my brain so..i post
will these fit my e30 IF i do a 5lug swap..a friend of mine bought them for her mk4 golf..and now she's second guessing(needs the coin)..i'll only take them off her hands if they're gonna work lol..
http://forums.vwvortex.com/zerothread?id=3095550
my car is a 1990 325is..h&r/bilstein sport suspension
if they fit could I get a suggestion of tire size too? I'm lookin to get some toyo proxies
tia!
grey4door 325ix parts car !!SOLD!!
http://www.maxbimmer.com/forums/showthread.php?t=79123[IMG]
kapt_krickee is offline   Reply With Quote
Old 05-04-2007, 11:24 AM   #423
215/40/16 all around if you want balanced handling, 205/45/16 fronts if you want the stretch to look more equal (the rears will still be more stretched) and yes it will mount (don't believe a tire shop if they say it won't).
Old 05-04-2007, 11:26 AM   #424
tia!
The problem is that the wheels have been modified, and are no longer valid 5x120 wheels. The pressed-in inserts most likely cover up the old bolt pattern, so they are not BMW wheels at all anymore.
On another note, if they still were 5x120 you'd need to be running E30 M3 5-lug to get them to work, which is like $1500+ in parts.
Old 05-04-2007, 03:12 PM   #425
kapt_krickee
kapt_krickeet
1500+ in parts..3200 for the rims(CDN plus shipping/duty--thats what she paid)
very very expensive upgrade..
I'm having a tough time finding wheels that i like... I really like this style..and want something with some width..
also liking BBS LM style..but have only seen that in 5lug as well..
maybe I'll just go with the dark bronze Ronals I saw awhile ago..(17's)
thnx for the input guys!!
Old 05-04-2007, 04:36 PM   #426
There are 4x100 BBS LMs. Look at the BBS Japan website (they are only in 17x7 ET40 last time I looked).
Old 05-04-2007, 04:45 PM   #427
kapt_krickee
kapt_krickeet
thanks mystikal!
liking the BBS RS-GT's also..but no 4lugs
http://66.249.91.104/translate_c?hl=...ial%26hs%3DtyO
Old 05-06-2007, 03:13 PM   #428
kapt_krickee
kapt_krickeet
ok..so..will these work on my e30??
LM 198 17×7.5 40 4/100.0 PFS 8.6kg
from this site...
http://www.bbs-japan.co.jp/pro/pro_i.html in the 17's section...
Old 05-06-2007, 03:22 PM   #429
ZiMMie
Send a message via ICQ to ZiMMie Send a message via MSN to ZiMMie
from this site...
yep with a 20MM Spacer.
www.StanceFactory.com
Old 05-06-2007, 03:29 PM   #430
kapt_krickee
kapt_krickeet
sweet!
how about these?
RG-R 712 17×7.0 38 4/100.0 PFS 7.5kg
in Diamond Black
I guess it's the same link..hate sites that do that..
but here's a pic
http://www.bbs-japan.co.jp/b_img/pro/rgr703_dbk200.jpg (of the 5bolt)
Old 05-06-2007, 09:06 PM   #431
kapt_krickee
kapt_krickeet
ok..found the ones I want at Tirerack..is this a good price? they come with the lug nuts required for vehicle..but..do i need spacers too??
thanks in advance for the hand-holding through my wheel search
here's my order so far..good to go??
https://www.tirerack.com/cart/SelectShipping.jsp ---> not sure if you can view my shoppin cart?
http://www.tirerack.com/tires/tires....cleSearch=true
^the rubber
http://www.tirerack.com/wheels/Wheel...ed&showRear=no
^the rims
http://www.tirerack.com/wheels/Wheel...0&autoModClar=
^the optional?
Old 05-10-2007, 12:11 AM   #432
Okay.
When you order rims from Tirerack, most of them are not E30-specific wheels, meaning they have oversized hub bores as well as incorrect offsets. What Tirerack does is produce custom spacers for each wheel that allow them to work as both spacers and centering rings, making the wheel effectively perfect for the car. For example with the RG-R's, they would probably ship 15mm (maybe 10mm) spacers as well as correctly sized bolts for your application.
The Tirerack BBS pricing isn't bad at all, but shop around local to see if they can match it (most likely not with the horrible USD right now). And the Pirelli Nero M&S is a really great tire, but get 215/40/17 (Tirerack's tire recommendations are off on many different cars for some reason).
-Jay
Old 05-10-2007, 08:15 PM   #433
Shurian
SpezE30
Shurian's Avatar
Tnks a lot Mystikal .
87 325e DD
89 325ic Project
Old 05-11-2007, 01:24 PM   #434
moock
e30fan
225 or 205 on 15x7?
hi all. great thread!
i'm running 15x7 Kazera KZ-M rims on my 1988 325e. i'd like to put either 205/50/r15 or 225/50/r15 on it. i'll be using the tires mostly on the street, and once a month at autoX driving school, which i'm starting this year.
tires i'm considering:
Falken Azenis RT-615
Michelin Pilot Exalto PE2
questions:
1) what are the pros and cons of going with a wider tire (the 225)?
2) is it true that the 225 will handle better than the 205?
3) is it true that 225/50/r15 will definitely fit a 15x7 rim without rubbing (no fender rolling required)?
thanks!
colin
moock is offline   Reply With Quote
Old 05-11-2007, 04:31 PM   #435
questions:
thanks!
colin
First off, neither of the mentioned tires come in 225/50/15, so I guess that solves that problem.
Pros of a 225:
Shorter stopping distance
Increased lateral grip
Aggressive look
Cons of a 225:
Decreased steering response
Decreased hydroplaning resistance
Increased tramliming
The 225 will technically handle worse, depending on your meaning of handling. The 225 tire is on the outer edge of recommended width for a 7" wheel, so the steering response can get sloppy, along with transitional stability. That said, with a stiff enough tire (BFG G-Force Sport, Yoko ES100, Hankook R-S2, etc) these downsides are minimized.
225/50/15 can fit without rolling (I personally did that), but it depends on the following variables:
- Car year
- Suspension
- Tire model
- Wheel offset
Provide me with all of those details and I can tell you if it will require rolling. Honestly don't shy away from the job, it's very simple.
-Jay
