Old 03-19-2007, 06:36 PM   #391
antonni95
What if the dish were removed and replaced with a shallower ones to bring them back to an 8.5 or 8 inch,would be a better option?
thanks
antonni95 is offline   Reply With Quote
Old 03-19-2007, 10:41 PM   #392
talltorontoguy
Go Topless
talltorontoguy's Avatar
Biggest Tire no rubbing: 17x7.5", et 21
Anyone running these sized wheels? What is the maximum width I can run on these without having to do a major fender overhaul. 215/40/17? Any bigger? A little rolling is ok.
1988 325ic
H&R, bilsteins
Rod
Join BMW Club of Canada! Click HERE
Best Engine, Bimmercruise '10 / 2nd - e30 Wild, Bimmercruise '10 / 1st - Best Cabrio, Trillium @ Tedfest '11 / 1st - e30 Wild, Bimmercruise '11 / 1st - e30 Wild, Bimmercruise '12 www.vertnation.com
talltorontoguy is offline   Reply With Quote
Old 03-20-2007, 01:17 AM   #393
thanks
Yes, making them 15x8 and running 205 tires will have a much better chance of fitting without rubbing.
Old 03-20-2007, 01:18 AM   #394
1988 325ic
H&R, bilsteins
Rod
Hey Rod,
215/40/17 if you just roll the fender lips. Kopi Alpinas are 17x7.5" ET20, guys with 215's usually need to do the rolling to solve rubbing issues.
Old 03-20-2007, 12:54 PM   #395
talltorontoguy
Go Topless
Thank you sir... always a fountain of information!
Old 03-30-2007, 07:33 PM   #396
calegrant
So I've decided on 16x9 borbet T's et 15 for summer. Only question I have is if they're a direct bolt on. I know the e30 is hubcentric and I see a lot of people running these wheels so I assume one of our wheel guru's might know if the hub is the same size.
Old 03-31-2007, 09:41 AM   #397
Not sure if those Borbets are hubcentric. Either way, it's not an issue as the shop would just use rings anyways.
Your bigger issue is that 16x9 ET15 wheels hit the front strut housings, at least on 51mm cars. The North American M10 318i has 45mm housings, no idea on whether they squeeze past those or if your car even has them. Just assume the worst, you will need 3mm spacers to mount the front wheels with 215 tires.
Old 03-31-2007, 01:32 PM   #398
calegrant
16x9's are available in 15, 25, 30, and 35 offset. Would either of these size's work to make it possible to run without a spacer?
Old 03-31-2007, 01:43 PM   #399
Gleb
E30 ..?
Gleb's Avatar
Jay, would you happen to know the weight of these rims?
Old 04-02-2007, 05:29 PM   #400
Nope, all of the other offsets will only require bigger spacers (and won't have as much lip).
Gleb, no weight data handy. I do know offhand that the 16x7.5" Type T is 19.5lbs, so figure something around 21lbs (rounded up).
Old 04-03-2007, 12:42 PM   #401
Slowered318
What do you guys think of the Ronal R-38 - 16"
Or is the LS still best for Mtech II - E30's?
Old 04-03-2007, 12:48 PM   #402
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
You need BBS RS or some other mesh style wheel.
Old 04-03-2007, 12:54 PM   #403
windsor318is
Nitrous Junkie!
windsor318is's Avatar
ryan those are gaaaaaaaaaaaay
Old 04-03-2007, 12:56 PM   #404
Slowered318
I agree but I would really like 16" ...oh well looks like another OE BBS season.
Old 04-05-2007, 04:32 PM   #405
Ryan, look into the 16x7 ET20 BBS RS replicas on eBay. Silver, gold, or black all with silver lips.
