Old 08-23-2006, 05:48 PM   #256
markw
markw's Avatar
Would these fit?
front
16x8.5 et 24 with a 2.5" lip and 205 40 falken 512s ****ty tread
rear
16x9 et 18 with a 3" lip and 215 40 falken 512s 80% tread
markw is offline   Reply With Quote
Old 08-23-2006, 10:08 PM   #257
Originally Posted by calegrant
No dents or P.O.S "spacers" will be used. I turned out a set and two spairs while visiting my old high school shop at the end of last year. I'm not a fan of spending 1600 on wheels that are properly balanced to cheap out on mounting them and have em shake like a 40 year old cougars vibrator on a saturday night
I ran cheap 3mm spacers on my $2100 17" RS'. Not a single vibration or other issue to present.
They are simply too thin to need to have any sort of good engineering, minus actually being 3mm thick.
Old 08-23-2006, 10:11 PM   #258
Originally Posted by markw
Would these fit?
front
rear
The fronts will need spacers. Issue is that you will need a spacer at least 7mm thick, and anything past 5mm but thinner than 15mm typically does not have a hubcentric lip, and will very likely vibrate.
With those bike tires, I'd run 15mm spacers up front, and something like 10mm in the rear to balance it out.
Old 08-28-2006, 07:21 PM   #259
ron k
Hi,
For my E30 ('89 325i) with 15X7.5 Ronals the conventional wisdom (Tire Rack) says 205/55/15. The Bridgestone S03 comes in 205/50/15 as opposed to 205/55/15. Any issues with that?
Thanks,
Ron
ron k is offline   Reply With Quote
Old 08-28-2006, 09:46 PM   #260
No issue, it will just look a bit small, the speedo will read slightly higher, your gears will be slightly shorter, and your fuel consumption will be slightly worse.
All slight changes. As good as the S-03 is though, I'd rather run the Falken RT-615 in the same size. Awesome tire.
Old 08-29-2006, 05:35 PM   #261
markw
markw's Avatar
You really are a tire/wheel whore, eh?
Old 08-29-2006, 07:57 PM   #262
Yes, but I think I'm finally settling down with these RZ's. No more one-week stands!
Old 08-29-2006, 10:55 PM   #263
calegrant
I'm talking about the cheap "spacers" most wheel shops throw on but throw off the balance of the wheel as they don't center the wheel on the hub like hubcentric rings.
Old 08-30-2006, 05:21 PM   #264
But we were talking about 3mm spacers.
They don't need any sort of hub lip, and they won't even be the same size as the centrebore of the car. It doesn't matter, at all.
Old 08-30-2006, 06:13 PM   #265
BmW1718
Send a message via MSN to BmW1718
what shops sell wheel spacers??
BmW1718 is offline   Reply With Quote
Old 09-02-2006, 09:28 AM   #266
Many wheel shops. Wheels Direct is where I got mine.
Old 09-06-2006, 05:12 PM   #267
Halfbroken
Hey,
I'd like to know if a 16 x 8 with a 38 offset will work on a 325is (87)?
0I'm looking to get a set of deep dish remotecs.
Halfbroken is offline   Reply With Quote
Old 09-06-2006, 08:37 PM   #268
Originally Posted by Halfbroken
Hey,
15mm spacers.
Old 09-06-2006, 11:36 PM   #269
dgmorr
Do most wheel shops sell hub centric spacers? I'm looking to pick up a set of proper quality spacers or stock wheels before i go on my trip through the states and have the wheels vibrate my car and me apart.
Old 09-07-2006, 01:54 AM   #270
Halfbroken
Originally Posted by Mystikal
15mm spacers.
Thanks!
